Planning on towing a travel trailer with my X.
#31
#32
Joshua
The sg2 (or most other odb2 gauge) will
Let you monitor a number of sensors on your truck.
Plus it is easily movable to another vehicle!
The advantage of ras over airbag iis the ras
is progressive and helps keep the rear springs
arched to reduce rear spring wrap which causes
rear wheel steer. Plus you can adjust it to tweak
it using a 12mm wrench to get it the way you like.
have onboard compressor w/airbags is great,
But i don't like all the extra plumbing and hw
especially if you have snow and salt in winter.
Just my .02.
Just my .02.
#33
Side question, would this grill fit my 2000 X?
It says it's for a 99 to 2000 Ford super duty.
!!!! 99-04 Ford superduty BRUSH GUARD
#34
Taking longer than I thought to leave on our trip.
I'm taking this time to better plan our rig load out. I didn't think we had time time to do a few of these upgrades. If it were up to me we'd already have done all the upgrades on my list, but I don't pull much weight in the decision making area and so far the answer to RAS, Helwig Sway bar, Air Bags and Red Head steering box has been "We're going to trying it out stock, and seeing if we need it." However I will be getting the 08' mirror upgrade and I bought the Prodigy p3, so I'm not getting skunked...
I'm thinking about the springs. These are the codes on them:
Front
YC35ACD
RPN2339
Rear
RPN2339
YC35 GC
What do I want and how do I get them?
Also, the tag on my rear axle says:
3 PM 421 ß
L30 10 5 9J16
I jacked it up and spin the wheel once and the drive line turned about 4-1/2 times.
What rear ratio do I have?
Thanks
Front
YC35ACD
RPN2339
Rear
RPN2339
YC35 GC
3 PM 421 ß
L30 10 5 9J16
Thanks
#35
Okay, checked the interweb and found a way to tell I have CG springs. Also I guess the codes I gave were basically pointless for determining what codes I have.
I was reading another thread and the process for changing out the springs sounds like way more than I'm willing to take on. If taking off the bumper is easier, than I don't want to know what's hard. I was considering this as an alternative to RAS or a rear sway bar, but both those could e done in an hour with my experience level.
Blah blah, I'm sure I'm sounding all flip floppy like a politician about four posts ago, so I digress. Ill just try to get the RAS and Helwig Sway bar on there...
Still wondering what ratio I have in the rear dif... Interweb, here I come...
#36
#38
Unfortunately for now all the family is going to allow is the 4 way sway control load equalizing hitch we already bought.
#39
#40
It actually pulls nicely stock, we're all just improving upon it. I'm doing so because I plan to drive with a family of 6 in the rig so in being picky about comfort and safety. I've seen people tow 13,000+lbs comfortably. However Ill admit its nothing like my 04' 2500 5.9 Cummins Ram at 20,000 lbs rated.
#41
Update:
The X tows our 30+ foot TT well as far as I can tell from what my father in law says. (I've been driving the Motorhome) We did no upgrades accept the Takunsha P3 and a 4way sway control. Oh, and a K&N air filter.
What I can't understand is the 6-7 mpg were getting. Both rigs are getting that mpg with identical engines. The X is 8k plus the 7k trailer so 15k. The motorhome is 25k easy with the 16 cargo trailer. I'm going to 5star the motorhome when I get around to it, but the X should be getting better right?
#45
I'm looking at doing mods that will pay for themselves. Right now with the X and our motorhome with the same V10 we're paying about $1/mile to drive. I was hoping to cut that to closer to $0.75/mile...or more
If possible.
