Sanding help
Old 01-28-2013, 11:18 AM
Tilleyman's Avatar
Tilleyman
Tilleyman is offline
Sanding help
I want to sand the interior of my '52 F3. I already removed all of the trim, gauges, grilles, etc. Would a mouse sander be best to get into corners, grooves, and rounded areas?
Old 01-31-2013, 10:27 AM
IndyDragon's Avatar
IndyDragon
IndyDragon is offline
Sure. There's no rule that says you must use this or that. Whatever you have that makes the job easier is perfectly fine.
Old 01-31-2013, 11:21 PM
2012F250SUPERDUTY4X4's Avatar
2012F250SUPERDUTY4X4 is offline
I found using an angle grinder with paint removal discs to be the fastest.
Old 02-07-2013, 07:25 AM
fixdent's Avatar
fixdent
fixdent is offline
I'm not sure this is what you want to do unless you are trying to strip the paint down to bare metal.
Are you just trying to scuff the paint down for refinishing or strip it off completely..??
Gordon
Old 02-07-2013, 11:52 AM
Since it's an old car I would think it's a restoration and doing it the right way for me is taking it to metal. Metal-prep then laying on sealer/surfacer base and clear unless he just goes with a lacquer and want to do a quick job.
Just my 2 cents.
89F150Guy84
Paint & Bodywork
07-11-2010 03:10 PM
JamesHajek
32
05-19-2010 06:13 PM
FordNFishinLover
Paint & Bodywork
07-22-2009 04:36 PM
afinepoint
Garage & Workshop
06-19-2008 11:33 PM
gruntwannabe
08-11-2006 05:39 PM
Quick Reply: Sanding help
