1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What are the options for bigger tires on 2012 F350 DRW
Old 01-25-2013, 01:57 PM
rmrichards949's Avatar
rmrichards949
rmrichards949 is offline
I could not find what I was looking for in the search, so hopefully this is not a repost.
I have a 2012 F350 DRW 4x4 6.7L diesel. I am wanting to lift it and put on bigger tires. What size lift do I need to put on 37s? I'm wanting to keep the factory ride as much as possible, as I lifted my old Excursion before and it rode real rough. The biggest problem right now is trying to find rims to support 35 or 37 inch tires. All the rims that I have found are only 6 to 6 1/2" wide, where as 35s and 37s need at least a 7.5 rim or wider. I did find some rims that would work but I'm not forking out 5,000 + for rims. Is the SRW front axle the same size as the DRW and the only difference is the spacer. Could I just remove the spacer and put on regular rims on the front? And what is the disadvantage to this?
Thanks in advance guys.
Old 01-25-2013, 02:13 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
You can run a regular rim right up front without an issue, I'm 99% sure. For the rear I would run a super single with that tall of a tire.
WhëëlMå1
03-04-2019 11:28 PM
jct377
01-23-2018 12:03 PM
hotrod45
08-17-2016 12:15 PM
tycot1
01-09-2013 09:20 PM
F350mikey
08-23-2010 03:58 PM
Quick Reply: What are the options for bigger tires on 2012 F350 DRW
