V10 spit a valve, done with this thing
Pulling a 10K load up Cajon pass in California at 4K rpm my truck started to run a little ruff. I crested the pass and made it back home. truck is in the shop now and right now they say that the #6 cylinder valves don't hold so they wanna do a valve job, they also say something hit the plug which I looked at and it's pretty obvious something hit the electrode on the plug. I also noticed when I got back that the truck had lost over 2 quarts of oil. So I figure a piece of valve or debris bounced around in the barrel, scored it and my oil went by the rings, so even if they do a valve job I seriously doubt it will run properly. Basically I'm done with this thing. I told them to put a plug back in it and I'm gonna drive it to Carmax and be done with it.
I just put about 4 grand in this thing back in October trying to beef up my towing capacity, 4:56 gears, Livewire from Mike, air bags and a Ypipe. I'm pretty much sick about it.
I appreciate the insight I got in fixing it up, the mods did help, the gears and tuner worked great, not sure I would do the Y pipe again though.
What about finding a replacement engine? I've seen a few on craigslist while looking for a different truck.
I threw two rods through the block of my 7.3 and found a replacement engine for $1100 with fewer miles than the one that blew. I replaced a bunch of parts on the new engine while it was on the engine stand and parted out some of the old engine. In the end it cost about $1000 and a some of my time to swap the engine out.
Just a thought.
Just a thought.
Truck is gone, Carmax gave me 4 grand, I really believe the rings are bad for it to have lost that oil, to get new heads or a valve job minimum and then deal with a engine rebuild I figure I'd be looking at about 5 grand for a shop to do it. Blue book is about 8 grand and I allready made up my mind I'm getting a different truck any how so I figure I just saved a bunch of hassle and in the end I get paid about the same for the truck.
Originally Posted by myerss
You guys may not like to here this but you asked!!
Today I came home with a 2004 Duramax, crew cab, 4 wheel drive 3500 dually. 44K miles, bone stock. Blue book is 32K, I paid just shy of 24K out the door.
WOW... Desperation sale there bro... How much did you lose? 8-10 Grand? Your ordeal cost you a LOT more than the $1500.00 a used V10 motor would have cost.
Thats really beside the point.. Hopefully you bought an 04.5, if you didn't, well... I hope you enjoy the $5k fuel Injector repair that due in about 30-60k miles
I like those trucks.. I just don't trust ANY diesel.. I hope your experience is better.
Thanks and good luck!
