Got the '54 Stripped, now the frame work begins
Old 01-13-2013, 04:38 AM
Forest_54_Ford's Avatar
Forest_54_Ford
Forest_54_Ford is offline
Hey guys, just thought I would show my progress. I've been busy with some time in between to work on the '54.
Here is the front clip off:
Then, with the help of a tractor, the cab:
Finally the bed and running boards:
When I took the cab off, I found several stress related cracks in the frame itself, tonight we got the pass. cab arm off and with the help of a great friend began to weld it back up. Ive found 1 pretty serious crack, it was almost all the way in half! The other 3 are less than an inch long. Very glad I went ahead and decided to strip it down.
Next I will grind off as much rust as possible and get several cans of satin rustolem.
And, over the Christmas break I picked up a nice little air cleaner and Holly 2bbl Carb for $50.
At the moment, I am a Happy Camper.
Old 01-13-2013, 05:24 AM
tacson's Avatar
tacson
tacson is offline
Looks like you are off to a good start. What are your plans for it?
Old 01-13-2013, 09:13 AM
WAY2LOW's Avatar
WAY2LOW
WAY2LOW is offline
I started my first '56 when I was 12, a '71 at 16, a '73 Bronco at 19, and a '53 now at 26 so keep it up!
Old 01-13-2013, 02:31 PM
Tbone54's Avatar
Tbone54
Tbone54 is offline
I started with a 46 chevy 1/2 ton at 14, a 75 bronco when i was 19, a 56 chevy 210 at 25, and now at 31 im working on a 54 f100
Old 01-13-2013, 04:43 PM
qmanconfused's Avatar
qmanconfused
qmanconfused is offline
i had all these things when they were new, now, i'm buying them all over again!!! what wrong with me!!!!!daaaaaa
q in 'cuse
Old 01-13-2013, 08:50 PM
Forest_54_Ford
I want to keep it as stock as possible.
Old 01-14-2013, 03:34 PM
55 f350's Avatar
55 f350
55 f350 is offline
welp your off and running and a good place to start with repairing the frame . i bought a new replacement for mine , another 53 frame from dave boley for 200 as i thought mine was twisted . after i stripped it down and relieved it of all it's weight i discovered the the left front springs are weak thus the resulting 1 inch lean it had . live and learn so now i got the oe frame as a spare for whatever purposes ...... i had a 55 fairlane 2 door , then a 56 crown victoria skyliner , then a 66 buick special 2 door , a 64 impala ss , a 67 bucik gs vert , on and on , and still going . somewhere over 100 cars and trucks , not too mention the race cars , motorcycles , and the future will most likely hold even more . the current stable is my beloved , but in many pieces 53 effie , my 95 beater bird that is broken down at present , and the 52 customline 2 door sedan . it's a disease that once you get it you can never fully divest yourself of it .......
Old 01-14-2013, 05:03 PM
AXracer's Avatar
AXracer
AXracer is offline
Glad to see that wasn't you welding without a helmet!
Old 01-14-2013, 05:50 PM
Forest_54_Ford
Oh no we had helmets, the first picture is an angle grinder cleaning up the weld area... Its hard not to look at the pretty blue light!
Old 01-15-2013, 03:52 PM
fking1's Avatar
fking1
fking1 is offline
Keep at it, U are on the right track, stay stock. Too many rodded ones out there.
Been exactly where u are now and completed mine about 6 yrs. ago.
Old 01-21-2013, 03:24 AM
Forest_54_Ford
Well the frame is now totally welded and fixed up. We cut up the front bumper and used it inside the frame for strength. worked well! Now ill fix the shock mount, the leaf spring bushings and then time for paint!
Speedcanuck
138
02-10-2022 04:03 PM
Sickler1
21
04-06-2018 10:28 AM
natewatts5
11-14-2015 12:11 PM
54TexasF100
22
08-24-2015 06:52 PM
Tsoptich
Washington Chapter
08-19-2012 01:44 PM
Quick Reply: Got the '54 Stripped, now the frame work begins
