I'm removing 6" lift with 37 x 13.50 X 18 tires off of 2005 Excursion back to stock HT.
Would like to use present aftermarket wheels with smaller tires on XD 10" X 18" wheels.
Type of tires: not aggresive Mud & not Highway tires Something like BFG A/T
? What size tire can I use with these 10" wheels 35's or 33's would like 35's if I don't have to fight rubbing can do a level kit if needed to use the 35's
Will use factory springs but want some good quality aftermarket shocks
? What Brand & Type of shocks should I use
Want a shock to help with the body roll you get feom this big SUV
What are you replacing th lift with? Stock Excursion springs? (hope not) F250/350 springs? I "lifted" my 05 Ex when it was 4 months old with Vs and modified Bs, F350 blocks, and F350 leveling kit. Netted me 3.5" of lift, and cleared my 33x12.5x20 Toyo A/T no rub, no trim etc. My 02 F350 is set up nearly identical and I run 35x12.5x16.5 BFG A/T with minor fender/inner panel rub. I trimmed the rubber inner fender, and that took care of 90% of the rub.
