93 5.0 Bronco surging and running rich.
#31
#32
Minor correction...run a vacuum line to the EVR (EGR Valve Regulator) then you will have proper EGR operation, assuming the components are in good working order.
For reference:
Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
Fuel Injection Technical Library » EGR Valve Position sensor (EVP)
#36
#37
If you leave the AIR tubes and hoses intact you open yourself up to an increased chance of falling prey to a leak somewhere down the road. it is not mandatory but be aware of the pitfalls.
#40
With the Thermactor system inoperative you will never "fool" the computer into making the engine run right. The Thermactor system is the fresh air injection that is comprised of the air pump, the diverter valve (behind the passenger cylinder head), the TAB and TAD solenoids, all of the plumbing from the pump to the check valves, the check valves (one atop the crossover tube between the back of cylinder heads and one at the upper end of the air injection tube into the upstream end of the catalytic converter) and last but not least, the HEGO (O2) sensor which is the single device that will ALWAYS tell the ECM (computer) that the fuel/air ratio is wrong if the Thermactor system is not operating. The ECM will compensate ad infinitum for the missing air injection. There is no way around it. End of story. Can you get the engine to run "pretty well" without it? Yes. Will it have adverse affect on the engine over time? You better believe it will.
Without the air injection, the system "believes" that the fuel-air mixture is "rich" consequently, the computer compensates by "leaning out" the mixture. In some cases it becomes so lean that hard starts are commonplace and get worse in cold weather. Spark plugs foul with greater frequency and cylinder walls super heat at EVERY engine operation. Fuel pressure regulators fail prematurely and if this has been the condition for a long time, the "rich" condition that you are chasing was probably PO induced to correct idle problems when the Thermactor was disabled.
#42
Thomas Boersma
03-24-2023 07:46 PM
husky562xp
05-16-2016 07:53 AM
dwildey
1978 - 1996 Big Bronco
05-19-2010 10:10 AM
eyancey
23
09-17-2009 07:43 PM
DavidTX85
07-28-2006 08:31 AM
