4wd frame swap?
Old 11-30-2012, 12:17 AM
shanesf100's Avatar
shanesf100
shanesf100 is offline
4wd frame swap?
I have a 59 2wd swb f100 . Id love to make it 4wd . Is ther any frames out there that would be suitable for 4wd swap. I'm new to the whole frame swaps so I haven't a clue what would work and what won't.my main goal is to lift it and puts some biger tires on it possibly light duty ofroading . thanks for your help.
Old 11-30-2012, 10:10 AM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Are you asking about a frame swap because you want to go to newer running gear & powertrain? No experience with the 2wd's of this era, but aren't they leaf-sprung on the front end? Wouldn't it be easier to just have new front & rear springs built & buy a solid front axle and T-case(cases for these trucks were divorce-mounted anyway)?
Old 12-01-2012, 12:10 AM
shanesf100's Avatar
shanesf100
I'd like to make mine 4wd and am trying to fin a easy way to do it .
Old 12-01-2012, 12:48 AM
19594x4's Avatar
19594x4
19594x4 is offline
Just find a 4wd 59 or 60 the running gear just swaps.
Old 12-01-2012, 12:53 AM
shanesf100's Avatar
shanesf100
Aren't the wheel bases off by a lot ? I know mines 110 inch
Old 12-01-2012, 01:17 AM
19594x4's Avatar
19594x4
19594x4 is offline
Just swap the front ends it all just bolts right up. I did it to a 1960 f100 2wd. I got a 59 factory 4wd drive that had nothing worth saving but the running gear, so I swapped the front end into the 60. And it all just bolted right up.
Old 12-01-2012, 01:54 AM
shanesf100's Avatar
shanesf100
Thanks a lot that's what I'll do then .
Old 12-01-2012, 02:20 AM
19594x4's Avatar
19594x4
19594x4 is offline
No problem, but if u plan on running big tires like 33 or up and plan on "wheelin" it I wouldn't use the closed knuckle Dana 44 they ain't very strong and someone correct me if I'm wrong on any of this
Old 12-01-2012, 02:49 AM
shanesf100's Avatar
shanesf100
Just big tires . Not really any hard core mudding or anything major.
Old 12-02-2012, 01:55 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Just to add to what 594x4 said. You could probably go for a little later model 4x4 as in 61-65 F100 series and get the job done too. I have not done this before so if that the route you can go make lots of measurements before getting involved on this suggestion. All the running gear looks very similar and I belive the frames are almost the same. Remeber you will need the cross member for the transfer case also. Thats pretty evident but thought I would mention it. 61-65 F100 will have the dana 44 front axle and they are leaf sprung. 66 F100 4x4 is based off the bronco front end has coil springs so would not be what you are looking for.
Old 12-03-2012, 01:08 AM
shanesf100's Avatar
shanesf100
Thanks for the tip. Can you guys give me a parts list of what I need to make the parts swap to the 4wd . Any thing would be helpfull I'm not that great at figuring out what I need .
Old 12-03-2012, 09:55 AM
1952henry's Avatar
1952henry
1952henry is online now
There are a couple of complete (running gear wise) F100s (63-64) in a wrecking yard nearby. Unfortunately, there are a few miles between NY and ND!
Old 12-03-2012, 04:22 PM
shanesf100's Avatar
shanesf100
I know seems like most of the good stuff left is west or south of here. I had a chance at a 60 f250 4wd bad every thing but the chassis eng and drivetrain . For 250. But I dident think about doing the swap till this past fall. That was last yr and has sense been scraped .
Any body that can help with the parts list for the swap it would be much appreciated .thanks
Old 12-06-2012, 10:45 AM
31tudor's Avatar
31tudor
31tudor is offline
I have a 1960 F250 Big Back Window FACTORY 4X4 for sale. Complete minus engine (was a V8), radiator, and bed. EVERYTHING else is there and front and back glass are not cracked. Axles, driveshafts, trans, steering and everything else you can imagine are there.
I'm a long way from New York but close to Las Vegas if you wanted to figure out what it would cost to ship it. No, I won't part it out, sorry. If you're interested you can call me at 435-668-1401.
Old 12-09-2012, 10:35 PM
shanesf100's Avatar
shanesf100
I wish I was a lot closer to you. If I wasent a few weeks away from unimployment I'd have no problem picking it up. Thanks for the offer anyway.
Ruckin69
08-26-2018 08:19 PM
Kuskoal
08-22-2008 12:07 AM
helrazr
11-02-2005 06:55 PM
Samsonitesamsonite
1983 - 2012 Ranger & B-Series
12-24-2004 03:33 PM
14miami
12-13-1999 04:06 PM
Quick Reply: 4wd frame swap?
