Gear Box & Hose Replacement for Dummies
  #31
Old 01-09-2013, 10:47 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
A few more pic's from Day 2...
Pic 2 - while you're in the neighborhood, check the 2 smaller radatior hoses to the oil filter, mine's gettin' thin where they rest on the engine cross member.
Pic 3 is the crux move; balance the box in one hand while lining up the bolt in t'other; either a forearm building exercise or profanity prelim!
  #32
Old 01-09-2013, 11:33 PM
EXv10's Avatar
EXv10
EXv10 is offline
Wow, that steering box was an ambitious undertaking. Another great write-up and you got a spot in the Tech folder! Amazing, and tribute to all women.
  #33
Old 01-10-2013, 05:45 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Thanks Brent, it was a long week with that thing and the wheel bearings a few days later but as well worth the effort.
  #34
Old 03-06-2013, 09:30 PM
Tom's Avatar
Tom
Tom is online now
Just a BUMP for those of us who participated in the latest group buy. Mine should be here this weekend!
  #35
Old 03-07-2013, 05:43 AM
sammie0126's Avatar
sammie0126
Just thought I would add the post numbers since this thread covers gas engines, differences in the install for diesels and another follow up post or two on things not covered in the original post (like pulling the pitman arm). Good luck everyone with your installs.
Gas Engines - post 1
Diesel Engine differences - post 17
Removing Pitman arm - post 28
  #36
Old 03-07-2013, 08:51 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Can't add to the rep., but had to try
  #37
Old 03-07-2013, 01:42 PM
EXv10's Avatar
EXv10
EXv10 is offline
Me too but she sure knocked it out of the park.
  #38
Old 03-07-2013, 01:45 PM
EXv10's Avatar
EXv10
EXv10 is offline
Sammie; careful with those tight fittings in the future, it's easy to round them off and then it's "break out the vice grips". They have fitting wrenches that grab more of the fitting and never round it off.
  #39
Old 03-07-2013, 05:01 PM
sammie0126's Avatar
sammie0126
Well thanks anyway!
Ok Brent - I've slept since then and don't know what you mean. The bolts that screamed all the way out? If so - lesson learned! I have rounded off more nuts and bought more pairs of vice grips in the last year than I care to admit. I have like 6 different sizes of vice grips. Just ordered a set of SAE and Metric ratchet wrenches today - to hopefully get my exhaust heat shields off intact when I do the manifolds and exhaust here in a few weeks. But probably wishful thinking - sure I will be at the hardware store buying some new bolts/nut after I give up and hack them off with the cutting wheel.
  #40
Old 03-07-2013, 09:28 PM
jh818's Avatar
jh818
jh818 is offline
Is this only for 4WD? Or is it the same for 2WD?
  #41
Old 03-07-2013, 09:42 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
You know, when I rescued my Ex from the clutches of my sister-in-law, I had to replace the steering box just to get the truck off the side of their driveway. The output shaft from the gear box had sheared off just ahead of the pitman arm. Nobody at the stealership had ever seen that one before.
Had to replace gear box and pitman arm, because nobody could press the broken shaft piece out of the pitman arm.
Outstanding write-up, by the way.
  #42
Old 03-07-2013, 11:08 PM
sammie0126's Avatar
sammie0126
Mine is a 4x4, and honestly never been under 2WD excursion so I'm not sure what the setup is with steering. 2WD guys - bump can anyone answer that question?
Thank you - it kind of got drug up from the recesses of a few months back because of the latest Redhead group buy. Was so glad to see that rusted hunk of dung off my truck!!! If I didn't have to send it back for my core refund I'd have used it for a boat anchor. Itching for this weather to break so I can start cutting my exhaust off.....you get your banks kit?
  #43
Old 03-08-2013, 12:33 AM
EXv10's Avatar
EXv10
EXv10 is offline
Well thanks anyway!
A wrench like this;
  #44
Old 03-08-2013, 01:19 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
A wrench like this;
I've always referred to them as a flare nut wrench. I've never heard them called by that name. Gonna have to remember that one.
Stewart
  #45
Old 03-08-2013, 05:40 AM
sammie0126's Avatar
sammie0126
Ordered two of these yesterday one Metric one SAE
6 Piece Ratcheting Flex Flare Nut Wrench Set - Metric
Quick Reply: Gear Box & Hose Replacement for Dummies
