$100 reward to anyone.....
Old 12-01-2012, 09:00 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
cracked pick up tubes....im not familiar. does eachvtank have a pick up tube? so i would have to have two cracked pick up tubes!?
Old 12-01-2012, 09:02 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
i took a video at start up. i also put it on youtube. but how do i get it up on this forum for all to see?
Old 12-01-2012, 09:17 PM
fordman67's Avatar
fordman67
fordman67 is offline
Originally Posted by kupiec20
rite now theres not much fuel in either tank. prob a 1/16 in each. lol
When I get down close to the e my fuel pressure gauge will fall off long before the truck starts to have symptoms.these guys are not steering you wrong in my opinion.
glovemeister's Avatar
glovemeister
glovemeister is offline
Copy the link here and we can copy the link and then view it.
If it does it on both tanks then I don't believe it would be a pickup tube. I don't typically run my tanks below 1/4 though. Does this situation happen with a full tank too?
Old 12-01-2012, 09:22 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
ok on youtube search 1996 ford powerstroke diesel mrkupiec20
Old 12-01-2012, 09:25 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
ill get fuel to them tomrw and give it a shot....stick with me guys. i need this fixed bad. ty
Old 12-01-2012, 09:30 PM
glovemeister
Ok, I saw your video and that sound really sounds like an injector/fuel issue.
Do you get smoke while running or only at startup?
Does this issue happen regardless of tank level?
Idm was swapped with a known good one?
Old 12-01-2012, 09:31 PM
fordpride's Avatar
fordpride
fordpride is offline
Need to get one tank over the 1/4 mark
Old 12-01-2012, 09:33 PM
glovemeister
The gurgling sound should be the fuel returning to the tank, as it was designed to do.
I'll do whatever I can to help, but it would be more helpful to know what it does with fuller tanks. Help rule out a couple of issues. Post back when you do that.
Old 12-01-2012, 09:54 PM
Red97350's Avatar
Red97350
Red97350 is offline
Old 12-01-2012, 10:18 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
ill chk back tomrw with a full tank... ty
Old 12-01-2012, 10:41 PM
dan7.3stroke's Avatar
dan7.3stroke
dan7.3stroke is offline
it sounds like only firing on 4 cylinders to me
  #28
Old 12-02-2012, 01:02 AM
95_Dually's Avatar
95_Dually
95_Dually is offline
Subscribed
  #29
Old 12-02-2012, 08:03 AM
F350-6's Avatar
F350-6
F350-6 is offline
the other thing i failed to mention was when we pulled the injectors.... the one on the drivers side closest to the dash almost shot out due to high fuel preasure. is that normal? and that oring was junk.
No, that is not normal. Which O-ring was junk? Is that the first injector you pulled on that side? Did you check down inside the injector cup to make sure you didn't have an extra copper washer in there?
  #30
Old 12-02-2012, 08:19 AM
Talyn's Avatar
Talyn
Talyn is offline
IIRC the rear tanks pickup tube is positioned weird.
But anyways, both pickup tubes sit about an inch or 2 off the bottom of the tank.
So there is a gallon or 2 of fuel always in the bottom.
Then if it is cracked anywhere above that....
The hutch mod is a great mod to get the best out of your tanks and eliminate the possibility of cracked pickup tubes because everything is stainless going back in.
But thats for another time.
Quick Reply: $100 reward to anyone.....
