6.0 engine missing bad
Nov 27, 2012 | 07:43 PM
have an 05 egr delete and banks six gun with sct tune for engine codes and tuning. at 60 to 70 crusing the engine just misses and only at crusing.
Also doesnt like to start all that well even at 60 degrees outside so any help would be great thanks
Nov 27, 2012 | 07:49 PM
Have you tried takeing the sixgun out of the equation and see if it still does it.
Nov 27, 2012 | 09:22 PM
Sounds like Injector
Check the FICM Main power at KOEO Crank Low Idel High Idel and Also check it under Load climb a Hill Fast and check Volts
I take it you use the Banks for Gauges ONLY?????????????????????????????????????????????? ???????????????????
Nov 27, 2012 | 09:26 PM
<p>Have you done stand pipes dummy plugs and upgraded the stc fitting?</p>
Nov 28, 2012 | 09:45 AM
I have this issue right now between 50 and 60. Just got back from an excellent diesel mechanic who ran diagnostics on it and my #2 fuel injector is kaputt..
Nov 28, 2012 | 07:15 PM
I ran some test and seems to be an injector thank u everyone for the help time to wrench it and get it fixed
Nov 28, 2012 | 08:15 PM
Quote:
Originally Posted by
mustang_309
Now your Going to wrench it do these Parts^^^^^^^^^^^^^^^^^ same time
You can Leave STC Fitting untill turbo has to come out or it fails or do it if have time
I would even rering all Inject with Alaint power product
Nov 29, 2012 | 10:16 AM
Yes I'm going to do a full upgrade and new head studs gaskets and turbo. Of course bigger injectors as well
Nov 29, 2012 | 11:40 AM
Make sure you have the upgraded fuel pressure regulator spring installed.
Brian
Nov 29, 2012 | 08:16 PM
j_yo23
Once you Mod the Truck like that better get a Regulated Return Fuel Sys
Once you go up inject size
How Much Money you GOT LOL
Maybe you should Bore it out For Bigger Pistons too Put alittle Gasser therory to it make it Go
some them H1-11 Stud
And a High Stall Torq converter So you can Lauch in Power Band Maybe a Tunner can Stall it Higher too
I got screwed
Oct 22, 2012 05:50 PM
schmity
18
Dec 26, 2006 11:29 PM
dagwood41
Sep 7, 2005 08:27 AM
