2013 terrastar 4x4 specs .... here they are
The E-350 passenger wagon and E-450 cutaway comes with a choice of the 5.4 or 6.8 gas engine.
Light Duty trucks are classified as class 1-3 trucks. Class 2A trucks are typically 'light duty' while class 2B trucks are often called 'light heavy duty'.
Medium Duty trucks are classified as 4-6 class. The TerraStar is in this group.
Heavy Duty Trucks are classified as class 7-8 trucks.
Here is a link with more details.
Truck Classifications | Light vs Medium vs Heavy Duty
Looks like the E series is back. My 2013 fleet brochure shows an E-250 cargo van. Engine choices are 4.6 or 5.4 gasoline engine.
Cummins Emissions Solutions will supply selective catalytic reduction aftertreatment equipment for Navistar diesels starting early next year. In addition, Navistar will begin buying Cummins ISX15 with SCR to replace it's own MaxxForce 15.
I always thought Medium duty was 25,000gvw and up. Guess I'm wrong. I stand corrected!
If I was to hazard a guess...I bet this was the primary reason why Ford stopped using Navistar engines after 2010. I know both sides sued each other but in the end it still is a business and comes down to the bottom line. Ford would probably have stayed with Navistar engines if they had SCR as long as the profit margin remained attractive.
If I understand the press release correctly...only the 15 liter engines will be the Cummins version. The other engine options will still be a Navistar engine but will have the Cummins SCR system. Simply put, Cummins has come to the rescue and agreed to provide Navistar a solution to comply with current emissions standards since it became obvious that Navistar's attempt at strictly in-cylinder (EGR) approach wasn't going to succeed.
Not for much longer though..
They are not light duty, they are a "mini" MD truck, and are very beefy and heavey duty.
The cabs are thicker metal than pickup trucks, the bumpers are powder coated, not painted with cheap chrome. etc....
I'm not a V10 hater, but they dont do well in an ambulance at all.
You may be correct. We don't have any use for the E series ourselves, I just saw them in our '13 Ford Fleet Guide. I wonder why the V10 hasn't been well received in the E series....they do just fine in our F series models.
And there are the little things too.. like brakes. They seem to work better with hydroboost than vacuum on these heavy rigs.
[IMG][/IMG]
Well, they are probably detuned, just like the diesels. The 6.0L in the E-Series is rated less than my 7.3L because they have no room to breath and cooling in the vans is terrible, so they detune it to keep things in check. Stuffing a 6.8L V10 under the hood probably isnt helping. Also, (treading in dangerous waters) the V10 doesnt have as much "OOMPH" in the seat of the pants that the diesel offers and that OOMPH is good to have when you are driving around a 12-14,000lb ambulance. Yes. I said that right. 14,000lbs for the modular ambulances I pictured above.
Does the V10 offer a dual alternator option? I know all of the diesels we have are dual alternator and even at idle we can drain the batteries if we dont push the parking brake in, which enables high idle.
#29
Here is a LoneStar with a little bling....I kinda like this truck.
(I wonder if the dealership sold this one yet? It has been sitting on the lot for a while now...)
