06 3.0 - Where would first point of failure be if ran out of oil - diagnosing what locked up
Old 11-29-2012, 04:24 PM
Christof13T's Avatar
Christof13T
Christof13T is offline
so...
im not pointing any fingers..
but somebody fergot the old seal from the oil filter and ended up putting new filter on with old seal still stuck up there.
oil vomit marked the path of the post oil change test run for a good 100yds before it went dry.
less than 1/4 mile from driveway to locked motor.
motor since been unlocked by pulling plugs, and intake... dumping in oil... and starter bumped it free.
bolted everything back together and after it worked the oil out it fired right up.
smoked for 45 minutes or so light black stuff i assume from burning oil off in exhaust.
good power...
no real loss in economy that was noticeable...
but it has a significant tick going on.
heres the rub.
motor is already out.
was replaced 2 years ago almost.
so no vids unfortunately.
basically i figure the best head start i can get is ask you guys what you think.
worse case scenario a ring job eh?
Old 11-30-2012, 12:39 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
If it locked and then busted loose, that would be reminiscent of my old two stroke dirt bike seizing, then running after it cooled off. If that happened, you will have aluminum from your pistons on your cylinders, just like my old Suzuki did. And you'll have a perpetual oil burner.
I can't imagine the mains and cam bearings escaped injury.
IMO, a complete teardown is required.
Old 11-30-2012, 06:04 PM
Christof13T
cams are good. crank... not so much i think... will get that uncovered tomorrow.
oil looked like someone dumped silver glitter powder in it.
will be parting out everything that wasnt damaged. if you guys need anything hit me up.
ill post pics of the carnage and of goodies left over.
madman72
10-17-2008 11:26 AM
66beater
07-25-2005 08:17 PM
Ed
Oil & Lubrication
01-25-2005 05:11 PM
Cape Guy
1997 - 2003 F150
18
10-08-2004 11:09 PM
oldfordtrucksrule
Oil & Lubrication
15
05-11-2003 07:54 AM
Quick Reply: 06 3.0 - Where would first point of failure be if ran out of oil - diagnosing what locked up
