Idle Control Valve
Old 11-10-2012, 11:00 AM
frmach's Avatar
frmach
frmach is offline
Question Idle Control Valve
When the idle control valve is replaced does the ECU have to relearn the settings?
Old 11-10-2012, 11:35 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Yes.
The IAC is a very important part to the operation of cold starts , hot starts, load takeup control for A/C, lighting and power steering loads changes plus deccellertion close down..
To do the relearn the quickest way, disconnect one led from the battery for a few miniutes as enough time for the computer to lose all stored changes to it's operating tables.
Reconnect and do a 'cold' start, turning lights on and A/C/heat/fan etc for max cold loading while recharging the battery.
Motor should go to a high idle then come down to normal idle as heat builds.
Let fully heat then do a drive about 5 miles out and back.
Do a couple hot restarts to load the motor with battery recharge load.
If there are no other faults, starting and running under all conditions should be perfect.
The procedure will have made the PCM handle all the loading it would normally see in this short time and continue to fine adjust over time..
Good luck.
Old 11-10-2012, 12:41 PM
frmach's Avatar
frmach
frmach is offline
Thanks Lots
Thought that might be the case. First time I drove it didn't see any improvement.
Today it seems much better. Will try your suggestions and see how it goes.
SuperSarge
1997 - 2003 F150
04-13-2012 12:44 PM
aintskeered
1997 - 2003 F150
04-16-2010 01:03 PM
RDavis
1997 - 2003 F150
12-02-2004 12:51 PM
shand32783
Aerostar
02-10-2004 11:08 PM
hemicbx
15
01-10-2003 10:19 AM
Quick Reply: Idle Control Valve
