6.2L V8 Discuss the 6.2L V8
2012 6.2L annoyance
Old 11-03-2012, 02:33 AM
azzy522's Avatar
azzy522
azzy522 is offline
Good to hear such good reports, I just picked up a new 2012 F-250 with 6.2 about 8 hours ago.
Lov'in it so far.
Old 11-05-2012, 06:44 PM
Knothole's Avatar
Knothole
Knothole is offline
We made our Colorado trip just fine and I am still not annoyed....by anything.
Old 02-13-2016, 10:18 AM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
I too have a hard time with the dipstick (oil). I'm learning how to be patient and gentle while utilizing the rotation without getting frustrated and trying to force it which it feels not right any how. I get real concerned about the little sheet metal connection to the dipstick tube breaking while pulling the dipstick out or putting back in.
Old 02-13-2016, 10:38 AM
Crumm's Avatar
Crumm
Crumm is offline
Originally Posted by Dave HM
Whoah, I got one now. This old pfart has a stiff back and shoulders this am after hooking up to two of the upfitter wires yesterday.
That is a real nut roll to get both paws under the dash there to splice into the wires.
I bet the designer does not have a clue how difficult he made it to reach.
Yeah the switches should be pre connected to the pass through wires and the pass through wires should be longer.
Old 02-13-2016, 10:41 AM
Crumm's Avatar
Crumm
Crumm is offline
Originally Posted by biz4two
Ok...here it is...the oil dipstick! Really???
I have wondered if mine got wound up in the crank. Do they all have a barber pole twist that looks like they were chucked up in a drill press?
Old 02-13-2016, 12:43 PM
R Guest's Avatar
R Guest
R Guest is offline
Where do you guys fill the oil to? To the line on the dip stick or the hole in the dip stick? My 2016 manual says to the hole in the dip stick. I was just wondering if that is what others are doing also.
Old 02-13-2016, 04:48 PM
dkf's Avatar
dkf
dkf is offline
Put the 7 quarts of oil in that is specified. Run the truck to circulate oil through filter and system. Let it sit for at least and hour on a level surface for oil to settle. Where the oil is on the dipstick is the normal fill level, mark on the dipstick.
When I first saw the dipstick on my dads 15' 6.2l I thought riveting a piece of plastic to the metal rod was a bad idea. If it comes loose or breaks you have to fish the plastic out of the oil pan. Don't know what is wrong with the all steel dipsticks that Ford has used for decades.
Old 02-19-2016, 12:43 AM
buzam's Avatar
buzam
buzam is offline
I put my 7 quarts in and that usually takes to just below the top hole... Perfect!
Old 02-25-2016, 07:01 AM
brickman's Avatar
brickman
brickman is offline
Might have to get rid of mine after reading about this major annoyance
Old 03-03-2016, 07:36 AM
wrvond's Avatar
wrvond
wrvond is offline
Here's my annoyance:
Sometimes when I am backing up I want to be sure which way my front wheels are pointing. There is a really handy screen that supplies that information on the display - except that it is covered up by the screen to turn the backing signal on or off.
Old 03-03-2016, 11:33 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
Speaking of annoyances.... My only one so far is after 10K on the clock, my supercab is starting to creak (near the top of the doors I think) when going over unlevel ground or speed bumps at slow speeds.. Anyone notice this also ? I checked the back doors to make sure they were closed. Maybe dry door rubber ??
Old 03-11-2016, 11:20 PM
dkf's Avatar
dkf
dkf is offline
They do that. I try to keep armorall on all the seals to keep the noise noise.
  #28
Old 03-12-2016, 05:22 AM
2009kr's Avatar
2009kr
2009kr is offline
I'm trying to decide between 6.2 and 6.7 for a 2017. (16k/yr daily driver, 2k/yr towing 15k.)
The dipstick synched it; clearly the 6.7 is for me!
  #29
Old 03-12-2016, 09:57 AM
clintbonnie
To tow 15K, I would definitely choose the 6.7L.. I only tow 7K with my 6.2L and I am wishing I had the diesel engine on every hill.. !!
Ya Ford saved millions of dollars reducing the thickness of the dipstick..lol..
  #30
Old 03-12-2016, 10:30 AM
2009kr's Avatar
2009kr
2009kr is offline
That's good to know. I tow 7500 lbs with my '09 F150 5.4. It does the job, but every hill is foot-on-the-floor in 3rd gear. (3700 RPM). Not too bad, but I see videos of the 6.2 running nearly 6000 RPM all of the way up mountains when towing heavy. I know the motor is designed to handle it, but it still causes me stress.
Quick Reply: 2012 6.2L annoyance
