Seems like the Chris Craft he's got is somewhere in the 4k range. He towed that all the way back from Arkansas with that truck.
then i would say no problem then...
Originally Posted by devino246
I believe gear oil and motor oil use two different scales...
i woulda thought so too.. but apparently theres a difference too between the gear oil itself and engine oil rating... Royal Purple, chevron and AMSOIL all seem to have it and say its different than motor oil... but cant find it anwhere...
hmmm owners manual says SAE 30 for the front axle... but this book says 75w-90QL
Front
Differential, Front......GL-5
All TEMPS......90
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
Rear - you need the friction modifier too if you have limited slip rear.
Limited Slip Differential, Rear Ford......GL-5*
All TEMPS......75W-140 [2] [3]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
if i went with Royal purple i wouldnt need the modifier... "Max Gear is formulated with a friction modifier additive – no additional additives are necessary."
Those are a good start. I have the whole Factory service manual on my hard drive if you need any specifics let me know and I should be able to email you pages.
lol parking brake for 1990 f250 4x4 info by chance?
Big mistake, trust me. Add the 1 bottle of friction modifier. Way too many people have had failures with RP and Mobile 1 syn LSD without adding the 1 bottle of friction modifier from Ford. The $6.00 for a bottle is worth saving the $2500 rebuild you will face unless you are going to upgrade to a locker later. The friction modifier makes the synthetic fluid more slippery and they dont run conventional from the factory anyhow. If it was a Mustang or 1/2 ton then might not be a problem, but all that added weight back there from a dually puts a lot more stress on the ring and pinion.
The 6.0 series of trucks are very sensitive to the fluids throughout the drivetrain.
Even the transmission requires a Ford only brand of fluid that is only available at the dealer. Nothing is an acceptable substitute.
didnt know that...
Its pretty basic. When you push down on the parking brake lever, it pulls a cable. That cable in turn applies pressure to the parking brake mechanism which is located on one of your rear axles.
If it isnt working, then either the cable is broke or needs to be retentioned or the sliders or springs in the mechanism are frozen or broken.
You have to pull the drum cable off to see whats happening. Pull the drum and have a friend apply the parking brake. Then you can see what is going on in there.
I'd trace the cable first. Likely it has stretched or broken over time.
Its the weight of the Super Duty rear ends. Huge surface area contacts compared to 1/2 tons and cars. Not worth the risk, especially with all of the failures I have read about.
had heard about that on the transmissions...
I buy it by the case. I have a few cases and filters if you want to pick some up from me. No biggie.
