Low speed squeak and more
Just got the entire front end of the truck redone, wallet and bank account empty, and now in true fashion... something else has to go wrong right before a road trip.
At low speeds under 10mph there is a squeaking sound, gets faster as the truck moves faster. Eventually it goes away and then there is a ratcheting sound, faint but noticeable. Plus when I rev the engine for a second while going a constant speed the squeak will reoccur for a second. As far as squeak, its loud. Very noticeable and people look as I very loudly drive by. I don't notice any vibration or abnormal feelings while driving.
The Brakes are clean and the sound isn't consistent with the brakes when I stop. The u-joints seem ok and are greased. I can't seem to find anything wrong.
What is going on?? Leaving for the trip tomorrow
It was kinda hard to discern noises (squeaks sound like birds) but it sounded once like I heard that noise with the engine off while you were getting out?
I'd check the transmission mounts.
Maybe it was birds, or my imagination, but...
'course, that's not gonna explain the fluttering..............
On the back of the transfer case? Haven't been able to get the driveshaft out so can't tell, but it seems like there is some play in it. I have pretty much eliminated all the other variables so I am about 99% sure that the slip yoke is the issue. Tomorrow I'll try to get the driveshaft off but I can't find a socket that fits the bolts on it.
I leave tomorrow on the trip, 3 hours 1 way. Everyone says "It'll be fine", but it isn't them driving a ticking timebomb. Call me paranoid but if its making a sound it isn't suppose to be making than I am not going to risk serious damage.
It should be a 12point 12mm for the bolts. I find a 12mm wrench (use the 12pt box end) and a deadblow or hammer of some sort to hit te end of the wrench with to break the bolts free. Some wd40 always helps. DO NOT use anything other then a 12point 12mm wrench/socket or you will damage the bolts been there done that lol. And don't forget to tape the dust caps on the ujoint so you don't loose the needle bearings.
