9 inch pinion bearing replacement
Old 05-16-2003, 11:58 AM
fordmaniac21's Avatar
fordmaniac21
fordmaniac21 is offline
my rear pinion keeps loosening up on my 9 inch rear axle. i am pretty sure that the bearing is shot. my question is if i replace the bearing will i have to re-shim and or set the pre load??? can i just use the old shims????
Old 05-16-2003, 03:30 PM
millertime300's Avatar
millertime300
millertime300 is offline
KEEPS Loosening up? You mean the yoke nut is backing off?
You are supposed to reshim your rear, but it will be so close you probably don't need to worry about it.
Old 05-16-2003, 08:28 PM
steve83's Avatar
steve83
steve83 is offline
You should only have to reset the preload if you're only changing the front pinion bearing. If you do any others, you might as well kit & reset the whole 3rd member because of the amount of disassembly you'll be doing anyway.
Old 05-16-2003, 09:17 PM
fordmaniac21
well i have tightened it several times and it keeps loosening up on me. thats why i am thinking that the bearing is shot.. i can take the pinion housing off right??? by the bolts that hold it on the 3rd member. it has been a while since i had a 9 inch apart. if i do the bearing i was plannin on shimmin it.
Old 05-17-2003, 09:38 PM
steve83's Avatar
steve83
steve83 is offline
The nut backing off doesn't indicate a bad bearing - it indicates a worn nut. If you can't get a new one, pull that one, hose it off with carb or brake cleaner, dry the pinion threads, put some threadlocker on it, and torque it to spec.
Royson12
24
07-01-2016 12:35 PM
Ron94150
08-28-2015 09:35 PM
peppermrj
06-13-2013 02:43 AM
80broncoman
08-31-2007 09:33 PM
Thomsen
09-10-2006 09:02 AM
Quick Reply: 9 inch pinion bearing replacement
