1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
f250 cant make it up a curb
Old 08-27-2012, 09:05 AM
AGE mechanic's Avatar
AGE mechanic
AGE mechanic is offline
Go up the curb one wheel at a time, would have helped A LOT.
Old 08-27-2012, 02:15 PM
HuntsDucks70's Avatar
HuntsDucks70
HuntsDucks70 is offline
Originally Posted by Crazy001
It gets even simpler than that. Use some common sense and drive forward onto the grass, this way you eliminate the possibility of a rear wheel slip and trashing your friend's grass.
Or recognize the fact that your light rear end would have a tough time pulling that heavy front end over a curb when your grabbing grass instead of pavement and putting it in 4WD in advance. Of course there is something wrong here, but there are better ways to get this done. Or maybe I'm just crabby from lack of sleep...
I agree with the majority here, it sounds like one or both hubs weren't engaging. Did you try manually locking them?
i hate to say, but, if you purchase the most accurate rifle in the world, and cannot hit the target, it is not the rifle fault. you really need to know how your equipment works and as said above, common sense goes a long way.
Old 08-27-2012, 06:24 PM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
Wet grass is tough. You need some good off road tires to move, even if your front hubs were working.
Old 08-27-2012, 08:23 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Ever since the ESOF left me my dad and brother and sister in the middle of white mountain lakes to be pulled out by a cummins 2 wd flatbed (did lift the dodge 3 to 4 inches of the ground in the front end till my dad slammed it). Well anyways that was without the hubs locked in esof then I locked it but that was to late. I lock the hubs before I leave our lot then when we hit the cattle gaurd I unlock it. I did get it fixed but I still don't trust it. On our last 02 we had esof and I never used it.
Trav
Old 08-28-2012, 08:52 AM
HuntsDucks70
loads of traction with the front tires still on the pavement, a lil bump also goes a long way
sitiakab
04-15-2019 08:46 AM
HMS
01-24-2016 03:53 PM
2jhanna
08-06-2007 09:38 PM
Dave85zxt
06-30-2005 10:19 AM
Lucky03
1978 - 1996 Big Bronco
01-17-2005 03:47 PM
Quick Reply: f250 cant make it up a curb
