2004 aviator abs
Old 08-23-2012, 07:10 PM
tritonman2001's Avatar
tritonman2001
tritonman2001 is offline
2004 aviator abs
Hi Guys
I am working on a 2004 aviator 2wd that the abs ratchets on during a normal stop. No codes and all the wheel speed sensors read correctly and match. What happens is the pedal will fall and then hit back up like the abs is ratcheting.
Thanks in advance for any and all help
Old 08-24-2012, 07:04 AM
shorod's Avatar
shorod
shorod is offline
Does it do this at every stop? How old is the battery? Does it do this immediately after pressing the brake pedal, from any speed, or is it only when the vehicle gets below a certain speed? The symptom you describe is consistent with the pump kicking in, I'm wondering if a weak battery combined with the load from brake lights is causing the pump to basically do a power on self test. I'm not totally sure the system does this, but it sounds like exactly what happens when I activate the pump with my scan tool while holding my foot on the brake pedal.
-Rod
Old 08-24-2012, 07:53 PM
tritonman2001
very similar to activating the pump with a scan tool. It only does it at low speeds, intermittantly, and the battery is good. We did figure out what was wrong, the rear end has a slight howl, and every once in a while, the rear sensor would miss read. Pulled rear diff apart and the bearings are junk letting the ring gear move side to side.
Old 08-24-2012, 09:44 PM
shorod's Avatar
shorod
shorod is offline
Wow, that's good information. I'm sorry you had to be the one to find it.
-Rod
foust123
05-07-2012 12:40 AM
Diesel-N-Bucket
12-14-2011 06:36 AM
f-250diesel
01-12-2010 01:14 PM
wallz
10-26-2009 07:23 AM
windstar99
1997 - 2003 F150
08-05-2008 11:42 PM
Quick Reply: 2004 aviator abs
