Couple questions about lifting my truck..
As much as I like the way some lifted trucks look, this is why I'm never gonna lift mine lol. Mine is stock and sits on 33''s, I can practically sit up under the bed and sits up plenty high enough for any off roading I will ever do. 3-4'' is tempting but over that and the geometry goes south. I purposely looked for one that hadnt been lifted as so many are hack jobs, plus it often means somebody has been thrashing the truck in the mud.
No, its a '76 F-100.
ps I'm not trying to rain on your parade, I just dont want to go through the hassle of lifting it plus while some lift looks great I have always liked the look of these trucks with just a little lift(stock in the case of 70s Fords) and slightly over sized tires. I remember back in high schools guys would lift these as high as they could using all kinds of jerry rig methods, drivelines would be all messed up; busted u joints and driveshafts if they could even get the front shaft in etc, handled like crap, rode like crap, bounced around etc basically unreliable
You should be able to fit 33s. You might have to level the front end though. I personally hate body lifts, I think they look cheap. They look even worse if you don't get bumper relocation brackets or gap guards. For a few dollars more than a properly done body lift, you could get a 2.5" or 4" suspension lift.
If that's the case then my vote would be a 4" suspension lift. If your going to ride trails the articulation you would get is far better with a suspension lift. If will perform much better off road and I think you will be much happier with it in the end. That's just my $.02 so take it or leave it
#29
I seriously think that for your application, getting a 2" spring and 2" lift blocks would be the best way to go.
Cutting the coil buckets and dropping them will work, but it's a lot more work. On top of that, a new spring will give you 2" on top of a "fresh" factory height, as well as additional flex/ride quality. Your existing springs have probably sagged 1/2-1" - so you'll actually net a little more than 2" of lift.
As for the rears - check to make sure that you don't already have factory blocks - if you do, measure them, and add 2" to the height. You may need to go up to a 4" block if the rear came equipped with factory blocks (my '78 F250 had factory blocks).
Look here:
Leaf Spring Blocks - Search Results for lift block - SummitRacing.com
Choose how wide your current rear leafs are (the F250 I have may be different than your F100), and then how tall you want the blocks. Most blocks cost less than $50.
Also on Summit, I found that you can get a set of 2" (or 4") coil lift springs for around $160-170. (Skyjacker 182 or 184 for 2" of 4" lift, respectively)
For just around $200 in parts, you can have a lifted suspension without modifying and cutting up the frame/coil buckets. The install will be easier, and the ride will be better!
-Brad
Look here:
-Brad
#30
One at a time.
1.The blocks will come in a kit,If you dont want to find a kit go to the junk yard and find another 4x4 Ford they all have blocks in back....BUT if your only going 2" get "Add-A-leafs" They will give you your truck ride
Search Results by 4 Wheel Parts
2.There is no grade "A" bolts they are grade "8" bolts and they are expensive and gold plated (Not real gold)
3.You have to cut the rivets, Cut the brackets and then make sure they are the exact same size and if the weld breaks you loose control of the vehicle! Ever blow a front tire? thats what its going to feel like,And you need to lower the track bar, If you dont have an idea of how to get the geomentry (sp?) right the tire will stick out the drivers side or passenger side too much.
4. If they jumped off a bridge you know the rest.... Look at a car with leaf spring notice the frame is on both side of the shackle even a Jeep,When you flip them there is no frame to act as a bump stop for the spring..."What will it change? I really cant tell ya I'm not an engineer but for one Its going to add alot of leverage on the frame for one, The engineers put it that way for a reason...
Keep in mind one day you will want to sell it, Most people wont buy a truck that has been hacked up especially when it comes to the safety of there friends and family and really would you want to chance of crashing with your wife and or your kids in the vehicle? Running into some one elses family and hurting them? Some things are just common sentence.
Some of this is why 4X4's get such a bad rap.
Come on man just buck up and spend 400.00 on a complete suspension system you'll be happy you did and have a nice rig to boot.
Why not just buy a body lift? Search Results by 4 Wheel Parts 125.00 and your done!
In fact I have a brand new 2" body lift with all the parts I'll sell you for 65.00 + shipping cost.
I've run a body lift in the past & like many who have I never will again. You talk about lowering the buckets being scary, yet you're pushing a body lift. Something is a bit backwards here...
Ok I won't tear this (or a couple other posts I've chuckled at while reading) entire thing to shreds as it would take way too long, but I will touch on a few key points.
I'm all for doing things right & not rigging stuff as well, but you have to realize what is "rigged" & what is not.
As for the weld braking & you loosing control of the vehicle - you seem to not have a clear understanding of the procedure being discussed here. The weld on what we were talking about is not the primary connection procedure for the bucket to the truck - or anything close to it. My guess is that weld could fail & he could drive daily on the thing for months & have no clue the weld broke.
There are 2 types of shackle setups - compression or tension. Both function in similar ways but have different benefits. A shackle flip is taking a tension shackle & putting it in a compression setup or vice versa. Both setups were offered in stock forms on many vehicles, so I am lost as to how one is so bad.
As to why "the engineer's put it that way" - it's typically because that's what the bean counters said they could afford to do.
4x4's don't have a bad rap or people wouldn't be buying them new every day. Hack job, redneck engineered 4x4's do to some degree, but that is when inferior parts or fabrication is used. Lowering a coil bucket, or flipping a shackle is not hacked if done right.
On a side note since I'm on my soap box - any given vehicle, even a purpose built race vehicle the suspension (and many other parts) are a compromise of budget limitations & space/layout limitations. You just have to work within these constraints to come
Now that all that nonsense is out of the way. Read the post above this, save some pennies & go that way. He makes a good point.
While blocks aren't the best way to do it IMO they do work. As for the front coil springs - they will save you a bunch of time. If you really don't have any $$ though then we go back to the original debacle.....
