00 Excursion on 38s w/10" lift HUGE system build log!
#106
Eeehhhhh. Someone stole your front driveshaft.... Kidding. It doesnt look like it was built well. It obveously had maybe air bags on the front because of the bracket bolt holes. It has double stacked blocks in the rear... A BIG no no. It has front spring drop brackets and shackles. Shocks look like generic replacements that fit the lift. It had dual steering stabalizers because the center bracket is still there. The previous owner took a bunch of stuff off and then sold it. The setup wasnt right or else he would have kept the front driveshaft in unless he didnt want to spend the money for a good driveshaft. Or he took it out before he sold it. The leaf springs arent that much of a lift because of the added blocks....ect. Sorry. I dont mean to down your X. But you should do some rebuilding of it to make it right. Its not your fault. The PO looks like he tore it apart and slapped something together to sell it. I wonder what gears are in it.
#107
EDIT: Without spending a million dollars lol. It is high enough and rides fine for me now compared to my Malibu. Just looking to spend a few bucks
#108
#109
I would replace the double block set up immediately with a one piece block and/or new springs. After that I would address the missing driveshaft and missing steering stabilizer. I wouldn't wheel in it at all with that two piece block, that makes me a little nervous. Just my two cents.
Would be kind of annoyed if the guy knew it was dangerous prior to selling it to me and just said F it.
And ya it being 2wd now I am just a driveshaft and new axle away from 4wd right?
#110
I haven't lifted a truck other than a level kit in a few years, but I was always told that there were two things you didn't do with blocks, you do not ever have them on the front axle, and you do not stack them. Now that was years ago, maybe things have changed with the two block deal. I can't say that they aren't safe without knowing who built the kit. I would have to have more information.
Yes with another driveshaft you should be 4x4 capable. I am wondering why it was removed? Was it as simple as the U-join went out, or a problem with the angle of the shaft, or something wrong with the shaft itself?
#111
#112
#113
That looks like the mount/yoke for the driveshaft going into what looks like a transfer case but it is hard to tell on my phone. Does it have the 4x4 selector shift on the dash? I assumed maybe wrongly on my part that the truck was a 4x4 with just the driveshaft missing.
#114
Anyone have a link to the bushwackers like these?
Custom Bushwacker Project pictures by TANKS250 - Photobucket
Can't seem to find them.
#118
Would the 02 suit my 00 body or should I get the 99 set?
02 2002 Ford F250 Super Duty Fender Flares - Body Mechanical & Trim - Bushwacker, EGR, Front, Front and Rear, Rear - PartsGeek
#120
