Hard Engine mods
Old 06-19-2012, 06:11 PM
96ford250's Avatar
96ford250
96ford250 is offline
Hard Engine mods
I have a 7.3 (1997) i'm going to shove into my 1996 f250 and i want to know is there any mods that are a big pita that i should do before i put the engine in and while its on the stand?
Old 06-19-2012, 06:17 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I also have a gas to diesel project. You do know that all the in dash wiring has to go too don't you? As far as mods, just about anything you would want to do would be easier with the engine out, but I would imagine the turbo/EBPV, or up pipes would be the ones I would definitely do while it's out.
Old 06-19-2012, 06:18 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
If I were doing it I'd pull the turbo and do a delete of the ebpv cylinder, unless you still want to use it. If you're gonna keep it, I'd still pull the turbo and put new orings under it so you don't have to do it later. JMO
A new downpipe, but you are probably doing that anyway on a transplant.
Home made bellowed uppipes if yours are bad.
Make sure your oil pan is in good condition. These trucks have had pans rust out bad before and only way to change it is to remove the motor. You've probably checked this, but want to mention it.
Can't think of anything else too hard to do while the motor is in.
Old 06-19-2012, 06:21 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Oil cooler o rings.
Old 06-19-2012, 06:22 PM
96ford250's Avatar
96ford250
what is the EBPV for? and the up pipes are the pipes coming up from the exhaust manifolds to the turbo right? mine look ok not rusty or anything is there an upgrade for them and is it worth the money?
ReBilld's Avatar
ReBilld
ReBilld is offline
Originally Posted by stainlessstroker95
Oil cooler o rings.
Yep, that's a good one too.
Old 06-19-2012, 06:30 PM
427 fordman
Bill's got your cheap upgrade for the uppipes link.
Old 06-19-2012, 06:33 PM
427 fordman
The ebpv is for help in warming up the motor. Most on here have it either unplugged or deleted completely. Mines gone. It can get stuck closed, more places to leak oil, etc. I'll show you a link, I did what gobstopper did.
https://www.ford-trucks.com/forums/9...or+rod+removal
Old 06-19-2012, 06:36 PM
redman84's Avatar
redman84
redman84 is offline
Maybe the front crank seal. I dunno what it's really called but they can develop a small, pesky leak.
And the dip stick seal if it looks worn AT ALL. Strictly diesel has a fix for it but boy is it an extra penny.
[quote=427 fordman;11971010]Make sure your oil pan is in good condition. These trucks have had pans rust out bad before and only way to change it is to remove the motor. You've probably checked this, but want to mention it...quote]
x2. If you put on a new one or reseal it you can also check the oil pickup tube as well.
Oil cooler o rings.
For sure!
Old 06-19-2012, 06:39 PM
427 fordman
Old 06-19-2012, 06:43 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Originally Posted by 427 fordman
I hadda go make a doo doo
Might be a good idea to just go all through the engine, as far as gaskets, o-rings, fuel hoses, etc., while it's on the stand. Do them all now and have no worries when it goes in the truck!
Old 06-19-2012, 07:13 PM
427 fordman
LOL!! Not exactly the response I was thinking you'd give, but I totally understand! I can get a good laugh most nights if I look for bill!
Old 06-19-2012, 07:26 PM
96ford250's Avatar
96ford250
the up pipes are a little pricey and not having a welder yet kinda makes it even harder to do. so the EBPV delete whats the best way to do remove it ive seen that it was leaking already and ive seen the kits online but what do yall recomend? i'm going to build the engine up alittle bit over time but im not going insane with it
Old 06-19-2012, 07:32 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Life's too short not to laugh all you can! I'm always cuttin up and laughing! It's one of the few things left you can do for free........I can't mention any of the others on here LOL!!
Old 06-19-2012, 07:35 PM
427 fordman
I cut that housing off the pedestal with a portable band saw, and took it somewhere that had an aluminum welder as I don't have one, to have it welded up. You can go the easy way and just thread a pipe plug in the hole that the rod comes out of. Only bad thing then is if you need to do turbo work sometime you have to work around that thing to get that one bolt out, and it isn't fun. I think that link I put up shows a few options. Just depends how involved you want to go.
Quick Reply: Hard Engine mods
