What fluids should I change at 70k miles?
Old 06-08-2012, 08:27 PM
Gundown64's Avatar
Gundown64
Gundown64 is offline
Howdy guys. My truck just crossed the 68k mile mark a few weeks back and I started thinking I needed to get some fluids changed in the truck. I think it is recommended to change out a couple different ones at 60k or so right? Well I'm a little passed that, but better late than never I suppose. I need to change the oil and filter anyway so I figured I get some others changed at the same time. Which ones should I be getting changed at this mile mark? Brake, tranny, fuel filter, headlamp fluid ? Recommend some brands, part number, etc if you can as well. Do you guys recommend letting the dealer do these things or can your typical shop do these without too much worry of having them screw up? Also, I need to get the tires rotated. How do you guys typically get yours rotated? X-pattern, front to back, etc?
Feel free to throw more info at me. I am young and still learning all this .
Thanks guys!
Old 06-09-2012, 06:04 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Scheduled Maintenance Guide: http://www.motorcraftservice.com/pub.../06frdmg3e.pdf
And for an added bonus, here's an owner's manual (4th printing): http://www.motorcraftservice.com/pub.../06f12og4e.pdf
Old 06-09-2012, 12:00 PM
Gundown64's Avatar
Gundown64
Originally Posted by shotgunz
I can't access those. I get an error saying I do not have permission. Looks like I need to be logged in or something?
Old 06-09-2012, 11:40 PM
FORD COASTIE's Avatar
FORD COASTIE
FORD COASTIE is offline
Supporter of Patriotism
Received 2,394 Likes on 1,732 Posts
At 82,000 miles on my old 2004, I had the coolant replaced and the rear end fluid replaced with royal purple. Prior to that, I changed my transmission fluid every 30,000 miles up to the day I got rid of it at 110,000.
Old 06-10-2012, 03:54 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Try this: https://www.fleet.ford.com/maintenan...ls/default.asp
or this: https://www.fleet.ford.com/maintenan...les/Getymm.asp
Old 06-10-2012, 12:07 PM
Gundown64's Avatar
Gundown64
Thanks Shotgunz, those worked and that was very helpful. According to that, the only things I need to change are my oil and filter (obviously) and then just a fuel filter. Everything else just says "inspect" this and that. I swear I remember more stuff being replaced at 60k but maybe I am just crazy .
Any suggestion on how to rotate the tires?
Old 06-10-2012, 03:47 PM
danorules's Avatar
danorules
danorules is offline
http://m.wikihow.com/Rotate-Tires
Pattern C is the one you want
Old 06-10-2012, 04:42 PM
Gundown64's Avatar
Gundown64
Originally Posted by danorules
Rotate Tires - wikiHow
Sounds good. Thanks Dano!
Old 06-11-2012, 05:47 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
I believe the preferred tire rotation is also in the owner's manual.
Old 06-11-2012, 07:36 AM
Gundown64's Avatar
Gundown64
I bet I would surprise myself if I read that thing lol. I guess I though all the secrets were not in there lol.
Old 06-11-2012, 09:42 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Yeah - there's a wealth of frequently undiscovered information in most owner's manuals (not just vehicles)...
dougf2504x4
05-10-2010 06:54 AM
dwilliamsceg
6.4L Power Stroke Diesel
01-20-2008 02:10 PM
Justin Time
02-16-2007 07:24 AM
98_lariat
1997 - 2003 F150
09-09-2006 03:48 AM
scott7512
1997-2006 Expedition & Navigator
05-18-2005 07:56 AM
Quick Reply: What fluids should I change at 70k miles?
