Bio + WMO mix?
Bio + WMO mix?
Since the weather has warmed up I've made my annual switch to B100 sold locally because it's 40 cents cheaper per gallon. I have about 20 gallons of unfiltered WMO that I've saved from my last few oil changes. Some of the oil is rotella blend 5w-40 and some is mobil 1 5-40 full synthetic and some is non-synthetic.
I have an in line spin on baldwin filter I added to my fuel system, how much should I filter the oil before I put it in my tank?
I'd probably only add 10% WMO at most, I'm in no real rush to burn it especially if it puts my engine at higher risk of failure.
Thanks
BTW my truck is described in my sig
Thanks
1989f250IDI
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-13-2012 09:10 AM
