Irritating problem
Old May 25, 2012 | 09:33 PM
austinlibke's Avatar
austinlibke
Irritating problem
Recently when i go out to start my truck, it starts up just fine, then will run for various lengths of time (Ten seconds to a full minute) then just die, like it runs itself out of gas.. Eventually it comes out of it and runs properly until i shut the truck off and let it sit. any ideas? anything appreciated.!!
Old May 25, 2012 | 11:06 PM
HD's Avatar
HD
Hmmm. I'm not too sure. The first thing you might try is to check the codes and see if anything pops up. Does the check engine light come on at all?
Chris
Old May 26, 2012 | 12:19 AM
Midnite1987's Avatar
Midnite1987
My first thought would be fuel filter. And that's something that it never hurts to change of you don't know when it was done last
Old May 26, 2012 | 10:32 AM
austinlibke
The engine light comes on yes, but it is not on all the time, the harder on the throttle I am, the less it is on. And just recently chnaged the filter. And still does it.. would it be possible a fuel pump relay or such?
Old May 26, 2012 | 11:39 AM
Midnite1987
Next step would be to pull the codes. even if the light Isnt on there can still be codes
How to run a self test - http://oldfuelinjection.com/?p=13
Old May 27, 2012 | 01:00 PM
austinlibke
Pulled the codes just a little bit ago, got 11- system pass, 12- idle control, 14-engine rpm signal fault or PIP circuit failure, 13- DC motor did not move, 31-EGR position sensor below minimum voltage, 41 oxygen sensor saying saying lean.. codes i got i got from the internet, so i am uncertain on if they are accurate or not. any confirmation on if they are or not would be much appreciated.
Old May 27, 2012 | 01:25 PM
Midnite1987
On the link I posted theres a link to the codes on the bottom. Did you do a KOEO and a KOER test?
Old May 27, 2012 | 01:26 PM
Midnite1987
Also what is your truck?
scottinjaxf250
Jun 4, 2010 08:53 AM
dkam
Aug 7, 2007 06:50 PM
Big 89 Bronco
1978 - 1996 Big Bronco
Dec 19, 2003 03:16 PM
Sleepy Paul
Jul 26, 2003 02:25 PM
whaynes
Jun 8, 2000 06:08 PM
