New Guy Trans Question
Old 05-08-2012, 12:50 AM
BlueBelle's Avatar
BlueBelle
BlueBelle is offline
Hey Gang,
I am the proud new owner of a short bed styleside 1960 f100 with a fresh 223 and a column shift 3 speed. I haven't owned a vintage truck before and I had a question to put out to the forum.
My trans intermittently grinds when I put it in first after a stop. There seems to be no rhyme or reason to whether it grinds or not. I adjusted the clutch to both extremes of it's range and found no change to the grinding, I adjusted the clutch to the recommended amount of play. Is this experience normal, am I just being paranoid.
Thanks in advance.
'Belle
Old 05-08-2012, 01:57 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,598 Likes on 1,303 Posts
Welcome to FTE!
Your transmission, if original, does not have a synchromesh first gear. It will always grind going into first. Try putting it in 2nd or 3rd before you try first. That will stop all rotation in the trans and make 1st easier to engage.
Old 05-08-2012, 02:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1963 was the first year for the Ford type 3.03 3 speed all syncromesh transmission.
1953/62 F100's have a "crash" first gear.
Old 05-08-2012, 02:13 AM
BlueBelle's Avatar
BlueBelle
Thanks for the info. I am sure you folks are going to be a huge help.
Old 05-08-2012, 06:43 PM
spurredon's Avatar
spurredon
spurredon is offline
Welcome to FTE!
jaggermk
11-06-2014 08:01 PM
bayou58
06-26-2012 04:22 AM
kbddbd
06-05-2005 06:20 PM
1bgredtk
10-25-2004 01:14 PM
Quick Reply: New Guy Trans Question
