First, thanks for all the help!
wheel base=133
color= QM
type= F105
body= C4
trans= G/ automatic
axle= 02J
Is the emissions any different for a 1976 360 vs a 1975?
Also does anyone have a vacuum line diagram for my truck?
I have looked in the Haynes manual and there is none.
We just finished straightening out the wiring that someone halfway rigged **#$*. All lights now work properly.
Thanks
JOhn
Im gonna say that Mil1ion has a scan in of the info that you are searching for, so as soon as he see's this, I hope he posts the link to it - but I dont know it off the top of my head.
I'll give you my help with the info anyways though
Wheel base is 133" which is about 11'
Color Code, I used to have the sheet with all of this info on it, but I seem to have lost it - it also has the trim level information.
F-105 is your model code and G.V.W., which is a 4x2 F-100 with G.V.W. of 5,100
Body code is basically your trim and body options, which I dont have with me at the moment, and dont remember off-hand, so..
Transmission code G - if I remember correct, this is a C6 - Because I think that my 78 Bronco reads G, and it had a C6 stock.
Axle 02J - This is your axle code, for a Ford 9" I believe with a 3.00 ratio.
Hope this helps. Its really late, so my info may not be correct, hopefully Mil1ion will come on here and post the link, Im pretty sure he has this information on his site.
JDM1975 opens a new thread every time he answers or posts. Email is blocked so I have no way to correct this situation. I have merged his threads several times now.
ADMIN- If you have a way to contact him please do.
JDM,
To find the info you required all you had to do was find a post of mine and click the link to my web site.
Also, in the sticky thread at the top of this forum there is a linbk to the info you require.
Do you know anyone with pics of the engine compartment?
Both harness's have plugs that come off of them that are hot but go to nothing. I have someones attempt at harness replacement going on here, with wires just twisted together and electrical taped.
Thanks again
John
Connectors, thats easy all black. I will take pics on thurs as I will be working all day and night tomorrow. There is a few other odd things too, like the can mounted next to where the jack goes over drivers side fender in engine compt. Its about the size of two large tuna cans together and appears to go to the wipers?
Will have pics thurs thanks.
John
No cruise. That canister hooks to some very small hollow tubes that are mounted inside the grilled vents just infont of the windshield. There is no brake booster that I can see. There is also a spade type connector coming from the coil that is hot but goes nowhere.
Where do I send the pics?
