Starting Problem
Old May 2, 2003 | 11:56 AM
oregon250's Avatar
oregon250
Starting Problem
I have a '93 F250 4X4 HD with a 460 and E4OD. Three different occassions after sitting all day, not all night, the engine has started and immediately stalled.
Yesterday it did it twice in a row and then started up fine. I was thinking either something electrical like the coil or maybe PCV valve?
Somebody have any ideas,
Geoff C.
Old May 2, 2003 | 11:52 PM
steve83's Avatar
steve83
Starting Problem
The PCV valve isn't electrical.
Pull the codes to see if the IAC or ignition module is acting up. Then put a fuel pressure gauge on it (hanging out the back of the hood so you can see it when you sit in the truck) & crank it. Just leave it in there for a week if you need to until the problem repeats a few times.
