Yep, same trans except for bigger syncros and some different gears. The 47's were only used in '96 and '97 models. Everything before that had 42's. You can look on the info plate on the side of the trans and see if it's a 42 or 47, made in USA or Germany, ratios and build date.
I also bought the 3rd gear bearing sleeve from drivetrain.com, they are good. The only thing i didnt get was the small parts kit which gives you new snap rings and shims(i reused the same shims and just bought snap rings in town). just make sure you have a torch and a good puller. I guess I didnt totally 'rebuild' it, just freshened it up with new bearings and syncros.
So '95 model trucks had S5-47s in them too? I thought it was just '96 and '97. They might be going by the trans build date maybe.
I'm putting the defibulators on this thread. I have a ranger build started on my ranger. But I also have my 96 F250 with the ZF5-47 in it. I bought nearly two years ago. It had absolutely no slave cylinder on it. I put a new one on and off I went. The trans was never too good from the start. The last guy wasn't much of a stick driver and so the third synchro and 1st are jacked up. But since I know how to drive well, I have kept the trans alive. I work at a company that sells clutch kits and the like. So I picked up a LUK clutch kit for 60 bucks. Now I am getting ready to order a new shafts and sychros. This transmission is finally done. Lol. I've been reading over a lot of posts and it seems 50/50 on whether you need the jig or not.
I think I may get a jig anyway seeing as my ranger build is receiving a ZF6...so ZF's will be full in my future. Lol. I am curious as to where I could find this jig at? As well as any upgrade suggestions? Thanks!
When I swapped the broken case on the tranny from the 97, I got the ZF tools off EBay. A seller by the name of Black Hat Auctions usually has a lot of Ford Rotunda branded tools. By the sounds of it , they go to a lot of Ford dealer liquidations. I don't remember what the numbers of the tool kits were that got, but all the tools for the ZF trannys don't come in one kit. While I just put a bearing kit in the tranny, I wouldn't have had to have the tool kit to do the job.
I will probably see what I can do without the jig toolset. Doesn't sound like it would be too hard to do if you know what you are doing.
As for the shaft, guess that was more for the Ranger's ZF6 its getting, need that to be in tip top shop for racing. I will most likely just polish the shafts in the trans for the F250.
