89 Bronco Rear end major pain
Yeah your gonna need new/used everything, if you get a used differential from ebay check to see if the spider gears are still there or send a message to the seller, how's the main ring gear and pinion?
Once you get everything out I'd check the housing for damage...like I said when I rebuild mine I got a used diff that still had the spider gears, I bought the master overhaul bearing kit to change out the carrier bearings on the diff, the pinion bearings and it came with all the shims.
Overall I think I spend a total of 250$ for the diff, bearing set and oil.
I would not go to ebay on this. Any junkyard will have lots of these. I got one in my garage. But I'm in the panhandle. You got to have some closer than that. Are you sure it's 355. Alot of them are 373. You may want to change. (I see big rubber) Of course you will have to change the front diff. But thats eazy on a TTB.
First I would be certain of the gear ratio. I haven't seen many 3.73 Bronco's though. Count the teeth on the ring and pinion then divide the gear teeth by the pinion teeth and that's your ratio.
Then get an axle from a local junkyard. Make sure it's the same style pinion. The older ones are flange and the newer ones use a yoke. You might have either one as Ford changed right around then.
https://www.ford-trucks.com/forums/8...ear-ratio.html
agreed seems thats what im reading. I will count and divide when i pull apart, there is no saving this axle some searious scoring and ring gear has broken teeth
Usually its stamped on the ring gear atleast on mine it was maybe because its an aftermarket?
Im wondering if thats why your rear end failed cause of that gear ratio with those tires?
Check this link out
Tire Gear Ratio Charts
This chart is basically saying you should have 4.88 gear ratio with those 39" tires
Check this link out
You're running 39" tires on this truck? No wonder the axle failed. You can't run tires that big on stock Dana 44 TTB and Ford 8.8" axles. They simply will not hold up to that kind of stress. Swap in another axle if you want but you'll be doing it again a year or two down the road.
You need some one-ton running gear.
#29
#30
