Need help Ford f150 transmission seap
I believe that number you posted is an earlier version of your transmission. It's an AOD which is mechanical/hydraulic. It will not work for you unless you make a bunch of modifications to make it physically fit.
The 4R70W is electronic/hydraulic operated. The computer will trigger a Check Engine Light when it does not see the 4R70W electrically connected. What is wrong with your current transmission? Since it is 100% electronic controlled any faulty engine sensor can trigger limp mode operation.
