Mustang "cosmetics" applied .....
- 2011+ Mustang GT engine/intake cover.
- 2012+ Mustang Boss 302 coil covers.
- raise the mounting points using 1½" square aluminum tubing cut in 1½" lengths.
- drill a ¾" hole in one of the sides of the resulting cube to receive the mounting grommets (part # BR3Z-9P686-A).
- use 3M double-sided attachment tape to attach the mounting extensions to the mounting points on the intake manifold.
- change 2 hoses
- the ½" vacuum hose that connects to the air intake tube. *Replace|shorten and relocate.
- the hose that goes to the coolant reservoir. *Relocate only.
- make a 9" x 2½" cut-out, notch in the RH (passenger) edge of the cover.
- paint the cover (including the chrome 5.0 emblem and trim) with SEM Trim Paint (part # 39143) - satin/matte BLACK.
- concern that the cover would trap/hold heat.
- air would still be able to flow over the intake manifold.
- minimize the hose (coolant, emissions, vacuum, fuel, etc.) changes and rerouting.
Using a hand-held, non-contact
LASER thermo-meter, measured the temperature of the cover after an hour of stop-and-go city driving - 139degrees. The intake manifold was 119degrees (same a without the cover installed).
And YES, the cover does set-up, off the intake manifold, however ...Modification pic's ...
Alternative Reference:
Installing the cover using the stock mounting points and changing / rerouting hoses - How-To ««« -click-
Other previous mod's shown, include ...
- ROUSH air intake.
- UPR oil catch can.
- oil filler extension.
-click- the pic'
Goth 150
< This space intentionally -blank- >
2019RRSDLARIAT
2017+ Super Duty
06-04-2019 08:15 AM
jh225
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
10-20-2014 03:28 PM
Spool&Go
17
07-24-2010 08:24 PM
DOHC330MustangGT
34
06-14-2007 01:23 AM
