How many Miles are on your 4.6/5.4 Modular Engine ?
Old 09-17-2013, 10:39 PM
tsd98's Avatar
tsd98
tsd98 is offline
Now at 197,000 on the '05. Drive it to work every day, no engine noise with the Mobil 1 5w-40. Good truck!
  #107
Old 09-26-2013, 04:27 PM
Ian LaRue's Avatar
Ian LaRue
Ian LaRue is offline
198k 4.6l 2002
started using valvoline maxlife 5w20 and no more start up smoke
  #108
Old 09-29-2013, 02:49 PM
Road Ranger's Avatar
Road Ranger
Road Ranger is offline
Originally Posted by drey04
check for broken exhaust manifold studs
Bingo! Right side exhaust manifold crack or broken stud.....and NOT a cheap fix up here in Canada.....$1,000 or more ?!?! Does anyone know if I can I expect better pricing in the Phoenix area this winter?
  #109
Old 09-29-2013, 10:13 PM
Ducky F150's Avatar
Ducky F150
Ducky F150 is offline
150600 third 5.4 in the truck
  #110
Old 10-28-2013, 10:47 PM
justforkicks's Avatar
justforkicks
justforkicks is offline
Just hit 305k miles yesterday with my 97 4.6! Got a bad exhaust leak thats trippin my CEL thats gonna get fixed soon.
My dad's 03 4.6 is at 299k miles last time i checked too! Long lasting motors for sure.
Oh, the 97 is an f150 xlt scab 4x4 auto, and the 03 is an f150 fx4 scab 4x4 auto. 97 was owned by electrician, 03 was owned by loggers.
  #111
Old 10-29-2013, 01:01 AM
Krisverde's Avatar
Krisverde
Krisverde is offline
Got in my step dads 03 today and realized it has 175k on it. Things runs damn good. Original trans too but from what i hear the 4r100 is a tank.
  #112
Old 10-29-2013, 02:51 PM
ericg70's Avatar
ericg70
ericg70 is offline
My '98 5.4L just turned 200K, it has the tow package with the oil & trans coolers and bigger rad. The 4r100 trans has had nothing but 2 fluid/filter services done. No motor work other than routine maint, 2 alts and a starter. Until the right side exhaust manifold rotted out, changing it next week. I run castrol High milege 5w20, burns about a quart a month.
  #113
Old 10-29-2013, 10:44 PM
xtamer's Avatar
xtamer
xtamer is offline
got my dads 03 expedition that he got around 30k, gave it to me with 220,000. he's never needed any major work done to it. just plugs around 150k, oil every few thousand, and a rear glass hatch (he backed out of the garage with it open and caught the door). I managed to slide backwards down hill in the winter while pulling our trailer, jack knifing, and denting the LR quarter. Then I had a guy purposely lock up his brakes in front of me smashing the front, racking up a $3000.00 body bill. ALL BEFORE 222,000!!! GOOD JOB ME. HOPEFULLY ILL HAVE BETTER LUCK IN THE FUTURE.
  #114
Old 11-01-2013, 04:36 AM
deputydog03's Avatar
deputydog03
deputydog03 is offline
Have 2 with the 5.4.
First is the wifes 2001 expedition. At about 160,000 the engine went. Now I have a rebuild in it, about 20,000 miles so far.
My pickup is a 99 with the 5.4. I got it with around 150,000 miles. A 110,000 miles the previous owner spun a bearing. It had about 30,000 on the rebuild when I got the truck. At 170,000 that engine blew up. About 40,000 on the engine.
The expedition gave us about 100,000 miles trouble free. Had to put an alternator on it, and had some trouble with the EGR pressure sensor. Other than that not a problem, until it blew. Over half of those miles I put on it was pulling a 30 foot camper, about 9500 pounds.
The pickup spun a bearing last summer while pulling the camper into a 40mph headwind. The timing chain guide broke causing the timing chain to rub on the cover. That filled the oil pan with metal filings. As far as I can tell it clogged the oil screen enough that 2 bearings chewed up.
I have to say I have had bad luck with the 5.4 engines, but they have served us well. Both have pulled our camper all over the U.S. We don't abuse our vehicles, but we do work them hard!
  #115
Old 11-03-2013, 10:16 AM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
07 explorer sport trac 4.6L 98000 miles. I know nothing about the previous owners/owner had the truck for about 6 months The engine has no leaks and the only problem is a weak master cylinder $560.00 to fix at the dealer {fluid flush also}.
  #116
Old 01-10-2014, 09:03 PM
SuperdutyJosh's Avatar
SuperdutyJosh
SuperdutyJosh is offline
2004 F350 Supercab SD SB SRW 5.4 with 74,XXX miles have only had it for just about a month now.
  #117
Old 01-15-2014, 04:47 PM
silvman36's Avatar
silvman36
silvman36 is offline
I have a 1998 expedition Eddie Bauer and it has 265,000 miles on it and just now replacing parts. Everything I have replaced has been original parts.
  #118
Old 01-27-2014, 08:59 PM
greaser14's Avatar
greaser14
greaser14 is offline
195k on my 03 f150 5.4 triton running strong no issues!!!
  #119
Old 02-03-2014, 07:41 AM
Rtlang's Avatar
Rtlang
Rtlang is offline
263k on my 99 E250 5.4
Runs strong everyday hauling huge loads of carpet & padding
  #120
Old 02-13-2014, 12:45 PM
JEL's Avatar
JEL
JEL is offline
123,000 miles on a 2005 5.4. Has the standard valve-tick but runs fine. Transmission just went out with no warning at 122,500. Truck is very well maintained.
Quick Reply: How many Miles are on your 4.6/5.4 Modular Engine ?
