HPOP LEAK
Old 03-05-2012, 07:56 PM
Oldsmoky92's Avatar
Oldsmoky92
Oldsmoky92 is offline
HPOP LEAK
Well I fixed the ebpv oil leak but now my hpop is leaking. I verified it for sure, I can see oil at the plug on rear of it. Would I be smart to install the T500, I plan on bigger injectors and chip in future. Any advice is appriciated. Thanks Chad!
Old 03-05-2012, 08:39 PM
fordpride's Avatar
fordpride
fordpride is offline
If oil is coming out of the plug on The back you can change the oring
A T500 couldn't hurt
Old 03-05-2012, 08:56 PM
Oldsmoky92's Avatar
Oldsmoky92
Ok well the hpop has 275,000 on as far as I know. How much is the t500 going for now? I will look into a super duty hpop tomorow, I have read they are an improvement over stock.
Old 03-05-2012, 09:21 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
If your truck is a '96 or '97 you can swap a SD HPOP right on, if it's a 94.5 or 95 you need a special HPOP.
I'd go with a T500 if you are planning on injectors and other upgrades in the future. You can get it from Riffraff Diesel for a good price.
Old 03-05-2012, 09:32 PM
fordpride's Avatar
fordpride
449.00 sending yours in to be built
Old 03-05-2012, 09:46 PM
Brown Falcon
$449 sending it directly to Terminator?
Old 03-05-2012, 09:59 PM
Oldsmoky92's Avatar
Oldsmoky92
Hmm. Its a 96. I am gonna have to make a decision soon cause I cant stand oil leaks! Whats the wait if I send mine off?
Old 03-05-2012, 11:22 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Hey Mike, how come a T500 could hurt?? hahaha
Old 03-05-2012, 11:35 PM
TerminatorEng.'s Avatar
TerminatorEng.
TerminatorEng. is offline
Chad, simple fix. Remove the 11/16" plug and replace the O ring with a Viton #6 O ring.
Old 03-06-2012, 02:18 AM
Brown Falcon
Geez Joey, don't you like making money???
Old 03-06-2012, 06:22 AM
fordpride's Avatar
fordpride
Glenn I fixed it
Old 03-06-2012, 08:46 AM
Oldsmoky92's Avatar
Oldsmoky92
Hey thanks Joey! I was trying to find a good excuse to upgrade.. Is it neccesary to remove to hpop to replace the oring?
Old 03-06-2012, 09:08 AM
oldbird1965
Just giving you a hard time Mike! lol
Old 03-06-2012, 09:30 AM
fordpride's Avatar
fordpride
I had to fix it so the op wouldn't think that maybe it would mess with his canooter valve or throw the exhaust bearing out of balance
Old 03-06-2012, 09:59 AM
fordpride's Avatar
fordpride
You don't I've to remove the HPOP. Removing the fuel bowl will give you all the room you need
Quick Reply: HPOP LEAK
