Speedo problem
#31
When looking up the correct drive (output shaft) and driven (end of the cable) speedo gears in the 1980/89 truck parts catalog, three things must be known.
Axle ratio, trans type and tire size. How many 1980's F350's (or F250's) came with factory installed 215/85/16, 235/85/16 or any other size of P-Metric radial? NONE!
If I knew what the 235 tires on your truck cross referenced to the original tire size, then I can give you the info.
However I got the original size from the door sticker. This truck I believe was an original chassis cab truck it that makes a difference.
Here is a picture of the door sticker.
Thank you for your help with this.
#32
#34
Bill, can you get him in the ballpark using my truck's information but with his transmission? My label and his both show the LT metric tires, or should it be tyres since they are both Canadian built. LT215 is an 8.50-16 as near as I can determine and LT235 would be a 9.25-16. I can pull my old C6 driven gear and get a tooth count if that will help.
#36
#39
#41
#42
That place (Dennis Carpenter Ford) is right down the road from me. I keep wanting to go by there but haven't yet. That's the extent of my contribution to this discussion!
Good going kedwin, I'l be interested to know what your mpg are once you have the odometer reading right.
#44
#45
So as I was driving it we used my buddys GPS and figured with the tire size increase I am reading 10% low. So if it say 50 it's actually 55.
When we pull the tranny I'll get the original gear info off it. Then once it's regeared I'll do it again with the gps and figure where I need to go.
