Electric fan CFM
Old 02-12-2012, 11:58 AM
wicat3's Avatar
wicat3
wicat3 is offline
Electric fan CFM
Hey guys I asked this in the 87-96 F series truck fourm and cant seem to get any good help. I have a 16 inch S blade electric fan that can do 2500-3000 CFM. I have a 302 in a 92 f150. I want to know if this 16 inch fan will cool the motor as good as the fan thats in it now or do I need another fan or what? Any help would be great.
Old 02-12-2012, 12:25 PM
kas83's Avatar
kas83
kas83 is offline
A quick search on Flex-a-lite shows the 97 and up specific fans as moving 5500 cfm in a dual fan configuration. I would expect your truck would require the same. However, if you're not towing heavy, I doubt that you'd have trouble with the fan you have.
Old 02-12-2012, 12:45 PM
wicat3's Avatar
wicat3
wicat3 is offline
so if i added another 16 inch fan i should be ok no mater what i do with the truck. I would only need to customize some sort of shroud for it.
Old 02-12-2012, 01:32 PM
kas83's Avatar
kas83
kas83 is offline
2 of those fans would definitely keep ya cool all around. Fab up a simple rectangular sheet metal shroud would probably be the cheapest/easiest route.
Old 02-12-2012, 02:36 PM
wicat3's Avatar
wicat3
wicat3 is offline
Well i have a buddy of mine with a simliar truck and has access to a sheetmetal shop so i could have him make me a simple shourd. A flange to screw around the radator and what not. Come off maybe an inch or two? Or do I need something similar to the plastic ones? I notice the dual fans with the shroud is just basicly blocking the bare radiator spots were the fans are not.
Old 02-12-2012, 05:05 PM
kas83's Avatar
kas83
kas83 is offline
All of the dual kits I've seen have either sheet metal or aluminum shrouds that mount the fans an inch or 2 behind the radiator. The idea is to have it closed around the fans so they are pulling across the larger, square surface area, rather than the round area of the fan itself.
Old 02-12-2012, 05:35 PM
wicat3's Avatar
wicat3
wicat3 is offline
Ill give it a shot and see what happens thanks
Old 02-12-2012, 07:56 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
I'm just not a fan of the aftermarket- had em, tried em, had toubles....OEM IMHO outflows all of them......even going back to the late 90's, Crown Vics/Cougars....all had e-fans and worked well.
Old 02-12-2012, 08:29 PM
wicat3's Avatar
wicat3
wicat3 is offline
I would go after an OEM e fan but I already have a fan lying around so its use it or chuck it and I dont want to chuck it so thats why I deceided to use this type of fan.
Old 02-13-2012, 02:31 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
You can use the aftermarket fan WITH your OEM fan, as a helper.
If you've ever heard to an OEM mechanical fan engage with the thermal clutch, it's pretty obvious that it pushes a lot more air than any aftermarket electric fans, and even some OEM electric fans.
Old 02-13-2012, 07:40 AM
wicat3's Avatar
wicat3
wicat3 is offline
Yea Im sure that is true but it also takes power away from the underpowered 302. Im trying to save some energy on the motor and help out as much as i can and ive read how much this helps
Old 02-13-2012, 05:57 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
...well, depending on the year 302, I can relate to under-powered, but, alot of these write-ups are well, pushed a little on creativity let's say, and in terms of sucking up power, there really is nothing much more efficient than a properly working fan clutch......with the new series engines, they OEM's are trying to get every last ounce of MPGs they can...& the e-fans are good for 1 MPG.
Old 02-13-2012, 06:02 PM
wicat3's Avatar
wicat3
wicat3 is offline
Its a 92. I have had this with a few other fourms on a few diffrent vehicales and most people hate e fans and I get it but id rather take my chances if it means I can get more power out of my truck and make it seem faster then it is.
Old 02-14-2012, 03:45 AM
kas83's Avatar
kas83
kas83 is offline
It's been proven to improve economy time and again, so I say go for it. The amperage draw, and subsequent parasitic loss from the alternator, doesn't outweigh the sheer power it takes to turn the mechanical fan.
Old 02-14-2012, 07:29 AM
wicat3's Avatar
wicat3
wicat3 is offline
Thanks Kas just need to find another cheap deal on another 16 inch fan to add with the one I have!
Quick Reply: Electric fan CFM
