1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front axle complete seal replacement
Old 08-28-2013, 08:28 PM
Ken05's Avatar
Ken05
Ken05 is offline
I tried renting the installers and no luck as they seem to be specific for this seal but I didnt have the numbers I posted above when I tried so that may be more usefull tracking them down. Someone has to rent them somewhere online might be the best bet.
Here's another photo seals almost completely seated.
Old 09-06-2013, 02:30 PM
jhill603085's Avatar
jhill603085
jhill603085 is offline
Well just about at the halfway point in completing this repair for myself, and this thread was definitely a life saver. Just have to put everything back together. Was not as bad as I was expecting it to be.
Thanks to all who have contributed some great info!
Old 09-06-2013, 06:43 PM
PSDlongbox's Avatar
PSDlongbox
PSDlongbox is offline
I would be tempted to put in a locker if i was rebuilding
Old 09-14-2013, 06:18 PM
Racer 693's Avatar
Racer 693
Racer 693 is offline
If the seal was not set correctly will it make the brakes pulse when you push on them? I did not have this tool and installed it best I could, now my front end is pulsing under braking. And a note I have new rotors and pads on it.
Old 09-14-2013, 06:45 PM
EXv10's Avatar
EXv10
EXv10 is offline
The seals have nothing to do with that.
Old 02-24-2014, 12:12 PM
TSM35's Avatar
TSM35
TSM35 is offline
Originally Posted by Ken05
Tool used for the big outer seal (aaa battery next to it for size reference )I picked up off amazon for 65.00 yes the tools were exspensive but I wouldn't want to gamble with the inner axle seals.
The tool seats them perfectly and I don't have to wonder if I was at the correct depth or if they were damaged with a homemade tool ( done that plenty)
Is there any chance you'd like to sell your seal spreader?
Old 04-15-2014, 06:28 PM
Takoda's Avatar
Takoda
Takoda is offline
oil seals
wondering if you can grease inside the seals where the rubber spins inside the metal housing? or is that pointless
Old 04-15-2014, 06:30 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
I do for the axle seal. The inside one...
Old 04-15-2014, 07:44 PM
EXv10's Avatar
EXv10
EXv10 is offline
It's always a good idea.
Old 04-15-2014, 08:33 PM
Takoda's Avatar
Takoda
Takoda is offline
Thanks figured it would help reduce friction, this maybe cheesy but i wasn't about to pay the big money they want for the seal driver so i made a make shift from home depot $15.00 2" x 10" galvanized pipe, with end cap and a large 2" floor flange set new seal on outter axle yoke and fit perfectly into and set the seal into the hub.
Old 08-04-2014, 07:08 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Thanks for this great write up bro.
So are these the seals that I need to change which are causing this leakage near the front u joint yes?:
Old 08-04-2014, 08:08 PM
EXv10's Avatar
EXv10
EXv10 is offline
No, that would be too easy, you need to change the ones up near the differential (past the cones), unless that is just water making it's way back out. The good thing is they won't leak oil while standing still.
  #28
Old 08-04-2014, 10:46 PM
02 Super Duty Guy's Avatar
02 Super Duty Guy
02 Super Duty Guy is offline
I have to do this in a few days so this write up will def make it easier for me where did you get the seals? any particular brand/kit to use?
  #29
Old 08-04-2014, 11:34 PM
EXv10's Avatar
EXv10
EXv10 is offline
Me? I didn't do it but there is a thread on how it's done..........do a search.
  #30
Old 08-05-2014, 05:54 AM
CollinsCD's Avatar
CollinsCD
CollinsCD is offline
Originally Posted by aldridgec
I had greased the bearings through the abs hole a couple of years back, but this grease accumulated behind the bearing in front of the seal. I believe some of it got sucked into the vacuum line for the 4x4 at some point. The dirt and grease clogged the line.
Great write up! Would you still recommend greasing the bearings through the ABS hole? I was thinking about doing that on my truck just as preventative maintenance. I'm also wondering if grease could get sucked up inot my vacuum line.
Quick Reply: Front axle complete seal replacement
