I have a 1992 F250 with 33s, no lift, no suspension change. I want to lift the truck up and put 35s on. Up front I have Fords TTB (Twin Track Bar) and a 10.25 solid axle in the back, strait leaf springs. I was curious if anybody knew a good company that still carries a lift for my truck? And if so, a good lift size for 35s? I was thinking a 6 inch.
Anything helps, thanks.
Jake
yup no problem. A friend of mine had an identical truck to the one in your sig, color and all, and had a 6 inch lift with 35" tires, it looked goofy. He should have put 38s under it.
Rough country has good lifts for that too. I have a 4" susp and 3"body running 37's. Looks fine and they only run about $700 for the lift and $200 for the body. Not bad, and pretty tough too. I have jumped this truck many times and had no problems with the lift. Other things are another story tho.
Idk about 33's on a 4". I had some on my 94 with around a 5" lift and it looked sad. Kinda like puttin regular sized shoes on a clown. 35's would be a much better choice in my humble opinion.
35's would be better, but I know for me its not fully in the budget. Plus I have new 33 BFG all terrains. Do you have any pictures of the 4" lift and 33's?
It just scrapped a 4" lift from my brother f250 when I put a Dane 60 in the front of it.
It was a rough county. rode like CHIT. The new F350 leaves w a fitted add-a-leaf rides better
Could I ask what the biggest difference/improvement was with the solid axil steering/ride vrs ttb steering/ride? Did the truck have any wonder or bumpsteer before? after? Other than the DANA 50-60 size I am wondering what the differance is ON road. final thought I hope the 250 you swapped was ttb lol.
As far as ride, the TTB springs have a much higher rate, so they ride like ****. The Dana 60 will out turn the leaf sprung TTB, and as far as bump steer, if brad setup everything correctly (which I'm positive he did, he seams real **** about that) then there won't be any noticeable issue.
