06 f250 5.4 lean
Old 01-13-2012, 03:22 PM
njglide1's Avatar
njglide1
njglide1 is offline
06 f250 5.4 lean
Having trouble with a 06 f250 5.4.It set two codes p0171 & p0174.Runs good but seems to studder on acceleration.Checked for a vaccuum leak and didn't find anything.Thinking maybe clogged injector?Any ideas would be appreciated.Also fuel pressure is 40psi.
Old 01-13-2012, 07:07 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
A clogged injector is more likely to throw a misfire, I would check the pcv valve and hose all the way to the intake manifold, no luck look for other means of unmetered air past the mass flow would be intake tube cracks, upper or lower intake manifold gaskets,a air leak that effects both banks
jkinghorn6.0
Modular V8 (4.6L, 5.4L)
20
10-29-2014 06:50 PM
okstatef150
2004 - 2008 F150
02-10-2013 12:51 PM
Mustang6147
1999 to 2016 Super Duty
09-26-2011 01:57 PM
lappy18
06-03-2010 02:42 PM
foxhundt
11-08-2006 02:04 PM
Quick Reply: 06 f250 5.4 lean
