4 Cylinder/Manual Ranger gas mileage?
Old 04-09-2014, 10:59 AM
greenpus's Avatar
greenpus
greenpus is offline
my 2000 2.5 got 27-29 mpg.
Because of my upgrades, I'm lucky to get 20 mpg
Old 04-09-2014, 11:56 AM
Conanski's Avatar
Conanski
Conanski is offline
Received 1,000 Likes on 787 Posts
Originally Posted by bowtieboy77
The next highest ratio would be 3.08. Is it your opinions that it would turn it in to a zero torque truck in 5th?
Yes. We had a '90 2.3 5-spd with 3.08 gears and it was the slowest thing I have ever driven.. could not maintain hwy speed into a headwind and OD was nearly useless on the highway. The thing spent most of it's life floored but it still returned a solid 25mpg everywhere all the time.
Incidentally our two 3.0L 5-speed trucks also return much the same gas milage but are much nicer to drive.
Old 04-09-2014, 12:52 PM
garthneddy's Avatar
garthneddy
garthneddy is offline
3.08s in a 2.3/2.5 powered Ranger is a terrible idea, it's just too much weight to push around with the amount of power available. Even with the 3.73s in my old 99 I still wished for more gear.
Old 04-09-2014, 01:20 PM
michigan66's Avatar
michigan66
michigan66 is offline
My '91 Ranger with 2.3 Lima engine, 5 speed w/OD and 3.08 gears was fine. True on a long moderately incline, I had to drop into 4th gear, otherwise if was more than adequately powered for 70 mph running, even pulling a trailer.
Old 04-20-2014, 06:25 PM
FarmingF250's Avatar
FarmingF250
FarmingF250 is offline
I had a best of 35 MPG (CDN gallons) in a 93 2.3 5-speed. I don't recall the axle ratio, but I am guessing it was a 3.08 from the description others give. 5th gear was not usable going up any grade, including at 60 MPH. I remember one time on a 70 MPH highway not being able to use 5th on flat ground due a strong headwind!
Old 04-29-2014, 09:18 AM
finn's Avatar
finn
finn is offline
I've got an old (91) 2.3, 5spd Ranger Supercab 2wd with, I think, 3.08 gears. The truck was priced right (free) and the powertrain moves it along fine. I have to drop out of overdrive on some long hills, but that's a small price to pay for 24 mpg local and 28 mpg highway.
nomadic
General Automotive Discussion
11-25-2007 12:02 PM
bryan_1980
10-14-2004 12:23 AM
scottie2hottie
4 Cylinder Engines
10-12-2004 04:21 PM
RBMNRR3600
18
02-03-2004 06:57 PM
lrs244
3.8 & 4.2L V6
08-06-2003 07:28 AM
Quick Reply: 4 Cylinder/Manual Ranger gas mileage?
