Ecoboost Fuel Tank change
Old 12-18-2011, 08:16 PM
SeattleJoe's Avatar
SeattleJoe
SeattleJoe is offline
Hello,
I have read quite a few messages regarding the 36 gallon fuel tank in the 2012 Ecoboost vs a 26 gallon in the 2011 models, but haven't seen that anyone has done the conversion. I have a 2011 FX4 and would like to convert to a 36 gallon tank. Has anyone done the swap? If so, does anything else need to be replaced other than the tank? Thanks
Old 12-18-2011, 08:43 PM
flixden's Avatar
flixden
flixden is offline
Yeah, I have seen at least a couple reports of the swap.
If I remember correctly, the gauges were confused, and the guys were not able to fix this. Basically, with a half full tank, it showed full, or something like that. All mpg readings were bogus as well if I remember correctly.
All in all, it appears to not be a very easy replacement. Well, the tank replacement may be easy, but not the computer calibration.
Old 12-18-2011, 09:29 PM
msgtord's Avatar
msgtord
msgtord is offline
Do a search. It's been done. The actual swap of tanks is easy. It's just the computer can not be programed for the bigger tank. Just one of the threads.
Old 12-18-2011, 10:23 PM
flixden's Avatar
flixden
flixden is offline
Yeah, for me, not being able to get the gauges and mpg readings adjusted would be a show stopper. But others may not care as much .... I mean - the gallons will be there, no matter what the computer thinks.
Old 12-18-2011, 10:33 PM
SeattleJoe's Avatar
SeattleJoe
I agree, I don't care in the computer doesn't register the gallons correctly, as long as the gauge is correct. Do you know if anything other than the tank needs replaced. I had heard that the heat shield and sending units may need to be replaced. I am going go to the Ford parts department this week and match all part numbers.
Old 12-19-2011, 05:15 AM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,229 Likes on 807 Posts
I'd be a little surprised if the dealer doesn't have the ability to change the programming on the fuel gauge and miles to empty read out with a tank swap.
Old 12-19-2011, 07:58 AM
msgtord's Avatar
msgtord
msgtord is offline
This guy had it done by the dealer and the programming could not be changed.
Maybe he will update the status soon.
HRTKD
Toy Hauler Towing; Fifth Wheel & Bumper Pull
21
10-14-2017 10:46 AM
smm0402
6.7L Power Stroke Diesel
07-25-2013 03:33 PM
tcdfwilson
02-13-2004 03:55 PM
f100guy
09-26-2003 10:51 PM
glk
09-22-2003 11:39 AM
Quick Reply: Ecoboost Fuel Tank change
