fuel pump is pumping but no start
#76
i did do some before testing but had nothing to compare it too. tonite i will have them clean ( been soaking all day in chemtool ) and will do testing again to see if the spray pattern changes any . it didnt seem like they was dirty to me but like you said on cold starts it may not be getting enough fuel . they cycled on and off with my toggle switch while releasing fuel when opened then shutting off also didnt see any drips because off leaking. tonite if i dont see a change they will be sent off for re-conditioning .i want them right the first time so there will be no question about them. i will let you know.
#77
#79
No not really thinking anything, just that injectors are not likely the problem. I will reread the thread but I am wondering if you drained the tanks and replaced the fuel filter. Your problem sounds like contaminated fuel (water). An easy way to drain the tanks is to use a marine outboard motor fuel line and squeeze ball (be sure to have it long enough to reach lowest part of tank), install into the fuel fill neck, drain both, then remove filter.
#80
I checked the injectors last night. There seems to be a cosiderable difference in the way they spray. So they was dirty but not stopped up. Do yall see any reason to have them bench tested ? The gas that was drained from the two gas tanks was put in my old farm truck 77 f250 4x4 and it has run not good but it has run so if it had water in it it was not much. I even put some in a jar to see if it seperates. It has not. So still thinking. ...
#82
Put them back in see how it runs.
#83
#84
The truck starts/runs when you introduce fuel/either, you have good fuel pressure at the time of starting...I would guess that your tanks are contaminated and that you also need to install a new filter...all the water will be at the lowest part of the tank & up if not recently agitated. You may also what to remove test/inspect the IAC, TPS, ECT, etc. but I don't think they are in play here....how could it possibly be the injectors, if the motor starts/runs with gas/either?
#85
I got time to test the injectors better this time. I'm using a 6ml syringe with the needle end cut off and it fits tight on the injector then using the plunger to push it through. When I set it on my bench and fill the syringe with b12. Some of it leaks through. So it failed the leak test right ? Then on some when I turn them on it flows fine but when I turn it off I can still push a small stream or drips through it with the syringe. So do you think with them acting like this the truck stayed flooded or can a EFI get flooded. ?????
#86
You're gonna have to take them all apart and do a real thorough job clean/inspecting them, you might be able to save them if you do, or just break down and replace the set.
My 94 runs good, real good in fact however I'm seriously considering ordering a new set for it, they are original around 100K on em now. Thinking maybe gain just a slight improvement in performance and equal maybe even greater boost in its fuel economy, the later enough to fairly quick recoup cost at rate feed it fuel every couple days.
#89
#90
Gonna have to review the whole thread look for anything overlooked first time around.
The fact it runs and runs well when manually introducing fuel via the throttle body suggests everything else works, least good enough for it to start and run.
Sensors are acting has enough air/compression at right time etc etc.
Something it originally died from, that obviously remains the issue reason PO bought new fuel pumps.
What you stated about conditions of the injectors yea would have been a problem, would have cause it to run poorly but apparently not "the" problem.
