So I got my hands on some Toyo's 325/60/20's
Old 11-06-2011, 04:38 PM
big dirty's Avatar
big dirty
big dirty is offline
Big Dirty has a 6" lift and right now it is sitting on 275/65/20
I picked up a set of (used) Toyo Open Country 325/60/20 yesterday locally for a good deal (I think)
I put one up next to the front tire and I really don't think they will make it, but I was wondering if someone has put these size meats under a 6" lift?
I am thinking about just going to the local tire store and have the fella take one old one off the front and put the Toyo on there just to see if it will work.
Old 11-06-2011, 05:05 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
What does that end up being
35inch? 37inch? Tire
Old 11-06-2011, 05:33 PM
big dirty's Avatar
big dirty
35.4x12.8/20
Old 11-06-2011, 05:37 PM
2006powerstroke90
You will clear without problems
Old 11-06-2011, 06:35 PM
big dirty's Avatar
big dirty
Thanks ...... I forgot to mention that the rims are Dick Cepek's and I think they are 20x9's
Old 11-06-2011, 08:35 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
you'll fit just fine. that will fit my 4.5" lift as well. depending on rim setup, you can stuff a 37" tire on your lift
Old 11-27-2011, 06:15 PM
big dirty's Avatar
big dirty
update ....... it appears that my rims are not the best back spacing. Tires are rubbing just before full lock.
I know I have lift because there are blocks in the rear and some sort of coil spacer up front.
I am going back to the original tires size and call it "happy"
Old 11-27-2011, 06:21 PM
2006powerstroke90
Are you sure its a lift kit?
I believe you would need a whole lift spring for 6inches, not just a spacer
Old 11-27-2011, 06:29 PM
big dirty's Avatar
big dirty
I am really not sure bud............
I do know that there are lift blocks in the rear (about 6" worth)
I try and get a pic of my rig in a few
Old 11-27-2011, 06:44 PM
big dirty's Avatar
big dirty
Here ya go
Old 11-27-2011, 07:01 PM
2006powerstroke90
Wow, thats such a pretty looking truck.
I am not sure that it does have a 6inch lift kit in it though.
They could have added back blocks, and just leveled out the front end, but by the looks of it, it looks leveled.
Which if they just added blocks to the back, and put a small leveling kit in the front it would have a rake to it, since they dont make any leveling kits bigger than 3 inches I belive.
Old 11-27-2011, 07:08 PM
big dirty's Avatar
big dirty
Thanks
yeah......love the truck.........always wanted one.
it has its quirks (still working on), but I love it.
what do you mean by (rake) ?
and yes ....... blocks in the rear and about a 3" spacer in the front coil's.
EDIT:
figured it out ......... Rake = rear of truck being higher than the front
Old 11-27-2011, 07:26 PM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
nice truck. all tats missing is 2 smoke stacks. hehehehe!
Old 11-27-2011, 07:41 PM
Ian123's Avatar
Ian123
Ian123 is offline
I'm usually a pretty good guesser but that's a tough one...definitely not a 6" lift though. Maybe a 2.5 or 3" front spacer with F-350 rear blocks?
Old 11-27-2011, 08:21 PM
big dirty's Avatar
big dirty
I iwll just go back to the 275/65/20 I had. I still have the (2) almost new Terra Grapplers....... I just need to find 2 more.
Quick Reply: So I got my hands on some Toyo's 325/60/20's
