Help decoding data
Could someone help decodeing this data? I have searched the Forums without much luck and also Googled this data, again without much luck. This is from a 1985 F-250, 4x4, manual trnasmission
The data is from the purchase documentation from Ford
Transmission: PE5TAAFA
Axle-rear: 39
Front Axle: D200G
Rear Axle: 126A
Thanks
Axle-rear: 39
Front Axle: D200G
Rear Axle: 126A
Thanks
Rear Axle Code 39 == 3.55:1 ratio 6,250 lb. capacity Ford axle, used 1985 and beyond.
