Mysterious soggy carpet
Help!
My carpet just inside the drivers side door right behind the plastic wear pad is soaked. I've dried it with a fan but it keeps coming back even when it isn't raining. I've looked underneath and can't seem to find a problem. I'm in Michigan and just brought the Bronco back from Arizona, the body of the Bronco looks like it just rolled of the assembly line, and the doors seal down low appears to be in good shape.
Any ideas would be much appreciated!
Thanks
Drew
Thanks
Drew
On the winshield you might need to pull it and get a new rubber gasket....depends on how hard it has gotten in the AZ sun......look for cracking....if you can find a place that looks suspicious you might be able to fill it with silicone.....or run a thin bead along the bottom of the whole thing....silicone on the drip rails will work just fine............make sure the cowl drains are not plugged and your cowl area is not holding water also
The fact that it gets wet even when it's not raining pretty much rules out the windshield and window seals. Do you use either the air conditioner or the defroster? Both of these will run the A/C compressor; the defroster runs the A/C compressor to dry the air even if the temp setting is on hot. And whenever you use the A/C compressor there is condensation that is supposed to go into a drip tube and out of the truck. If your drip tube is missing or broken or fell off or is clogged etc. then the condensation will go onto the floor. This may not be the problem, but it's a lot more logical than saying the windshield and/or seals are the problem (no offense to that poster) when it gets wet even when it doesn't rain. It could also be a leaky heater core, although that is on the passenger side behind the glovebox. But I would not rule that out because the heater core may be leaking and the water is running down the dash and coming out on the driver's side. When the truck was in Arizona I'm sure the A/C was used a lot, and in Michigan I'm sure that the heater and defroster are used a lot. The heater core leaking would show itself whenever you use the heat; and the defroster leaking would show it when the defroster is being used (or A/C in warmer weather). Unless the heater core is leaking catastrophically, you'd only see a small amount of moisture; and if the condensation drip tube wqas leaking, even if it is gone completely, would never show a HUGE amount of moisture all of the sudden but it would build up and soak the carpet. So check those two things. I just don't see any window seals etc. being the problem if it still gets wet when it's not raining. Hope this helps you.
It's not the heater core if it's on the LH side.....plus it would fog the windsheild....and smell sweet if there's antifreeze in it.........no mention of that....if it's not raining where's it coming from ??.....never stated time between rain storms....the AC evaporator is right next to the heater core......left hand side....my Bronco floor fills up in the same spot RH side everytime it rains....garage it ....bet it goes away if not driven in the rain....
I'm mostly concerned about the fact that is gets wet even if there's no rain. I know he did not mention the time between rains but he did say that he dried it and it came back without rain. That right there almost proves beyond shadow of doubt that it's not a windshield or other seal. As far as dew and/or frost that's a long shot too but I suppose it's possible. But if you have a leak bad enough that dew or frost soaks the carpet then it should be very easy to find.
It doesn't rule out rain.....He could have a cowl drain plugged holding water ......slowly seeping in...........if it had no antifreeze in MI....he'd have frozen up by now.....true........... water can enter a long way from where it drips.....but it can't climb the trans tunnel
drew i dont know what year your bronco is but on all of my 79s i had the same problem there is a cowl rubber on the fire wall [engine side] that channels water away to the side if that is missing/broken water will seep down the fire wall,and travel inside on the wires if the grommets are missing/loose that drove me crazy for years till i finaly put the water hose on the hood and seen where the water was entering just a thought to try
ive been having almost the same issue - the soggy floorboards. But mine only leaks when it rains. My Bronco's an 84, so 29 years old this year? I pulled off the kick panels on both sides off and the access panels and YUCK!!!! Pine neddles, leafs, tree seed pods had been in there sssooo long that I had soil in the cowel drain holes. There was so much crap that it was up to the bottom of the acess hole & after I cleaned it out I could fit my whole hand down in there.
Moral: clean those cowel drain holes. lol
