1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Turn Signal Problem
Old 10-25-2011, 08:45 PM
fishdip's Avatar
fishdip
fishdip is offline
Turn Signal Problem
So I have an issue with my fuse that controls my turn signals and brake lights. It start with when turning on the left hand turn signal the fuse would blow now that I have done some work on it to find the issue when I put a fuse in it blows with out the truck running or anything.
What I have done:
  • Checked the light bulbs
  • Checked the light bulbs connectors and assemblies
  • Disconnected the Trailer assembly
  • Taken apart the steering cloumn and checked the switch assembly (this is when the problem got worse)
It is a 2004 F350
Old 10-26-2011, 09:18 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Welcome to FTE.
Sounds to me like you have a wire that is chafed and grounding out.
cdat81986
18
09-14-2022 08:02 AM
hayden01
Electrical Systems/Wiring
15
10-25-2017 05:39 PM
RIKIL
03-27-2014 07:05 PM
Ordnance
12-17-2013 08:28 AM
optiboli
04-12-2006 02:51 PM
Quick Reply: Turn Signal Problem
