I have a 2011 F350 and I want to replace the steering wheel. The only problem is I can't figure out how the remove the airbag. Does anyone know how to do this?
I looked it up in ShopKey, but it had very little info on the 2011 SDs. Two options that I would go with if I were you: 1) Go to the dealer and have them look it up and tell you how to do it, or 2) Go to a local, reputable body shop and have them tell you how to do it. Either one is free and might be the easiest source. Someone may come on here and know, but there are two more options for you.
