number 8 injector has different part number
Old 10-06-2011, 05:11 PM
rockinxj's Avatar
rockinxj
rockinxj is offline
I was looking at prices for 99-03 injectors and noticed several companies have a part number for 1-7 cylinders and one for number 8.
What is that all about and what happens if you put a 1-7 in the 8 hole? I ask because I replaced number 8 a week ago and now my truck is pushing oil into the fuel rail. I plan to pull them all for calibration and cleaning. replace as needed and go back in with new o-rings. I will ask the techs at the injector shop too.
Just wondering if anyone here had heard of this before.
Old 10-06-2011, 05:24 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
As for the oil in fuel sounds like the Injector Orings.
Number 8 had a TSB for the noise being a dead headed fuel system, they installed an AE code injector in #8 which is also called a long lead injectors as it is mechanically tuned to deliver a longer lead time to allow for less cackle. Technically you can run either, I run AD's which are 1-7's. But I also have a Fuel Rail Crossover to eliminate the dead head issues.
Here is a great place to get some injector's if you are in the market, Clay has New Alliants as well if that's what you are into.
Riffraff Diesel Performance Parts: Diesel fuel injectors | Ford Powerstroke fuel injectors | 7.3L Fuel Injector - Full Force Diesel / Casserly
If you wanted to test them
Riffraff Diesel: HEUI Flow Testing
Then even some of that can be recouped if you go with injectors there too.
Old 10-06-2011, 10:37 PM
rockinxj's Avatar
rockinxj
rockinxj is offline
Thanks for that info. I am new to powerstroke diagnosis and repair. I have owned 3 before this one but this one is my "new toy" so I'm doing the repairs and upgrades myself.
Did you build your own crossover or just pick one up from a vendor?
Old 10-06-2011, 11:24 PM
BigAlsPSD's Avatar
BigAlsPSD
I did mine myself, using materials and the idea very similar to Clay's offering, which I believe was Kwikordead's original setup, but if I needed another one, no hesitation getting Clay's Frx, I think it's cheaper than the time and money I spent building mine.
Riffraff Diesel: Fuel Rail Crossover™
Old 10-07-2011, 09:35 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Alan,
Are you sure the AE is mechanically different inside? I always assumed just the solenoid was different and "long lead" referred to a delay built into the solenoid so the SOI was a tiny bit later than called for.
I've taken apart AD and AE side by side and they looked identical inside....but I didn't measure the parts with a micrometer so perhaps there are microscopic differences?
Old 10-07-2011, 11:29 AM
ballbandit's Avatar
ballbandit
ballbandit is offline
it is the solonoid that is different.
Old 10-07-2011, 02:58 PM
BigAlsPSD's Avatar
BigAlsPSD
I shouldn't have used that wording mechanically, I suppose, thanks for the correction.
Old 10-07-2011, 06:14 PM
aklim's Avatar
aklim
aklim is offline
I'd rather use the Strictly Diesel unit which is nicer and has a fuel pressure regulator instead of springs. That or Diesel Innovations.
Old 10-07-2011, 06:52 PM
Shake-N-Bake
No biggie.
I was just wondering because I have always wondered myself. I have looked around and never found a definitive answer. I was sorta hoping that you might know of a link to an article that talks about the AE with more detail.
Old 11-04-2011, 10:46 AM
Shake-N-Bake
Number 8 had a TSB for the noise being a dead headed fuel system, they installed an AE code injector in #8 which is also called a long lead injectors as it is mechanically tuned to deliver a longer lead time to allow for less cackle. ...
Alan
I thought I'd follow up on this conversation. You are correct. The AE injector is mechanically different (according to Jim at Rosewood). I asked him and he said the AE has a slightly shorter intensifier piston which causes the injector to begin it's prime shot a tiny bit sooner than an AD injector would. He said it's such a small difference that he has his doubts that it solves any issues at all but Ford thought it was worthwhile so that's why they did it.
I believe machining down the intensifier piston is one of the ways these injectors can be modified to increase the amount of fuel they provide. So, if the AE has a slightly shorter intensifier piston, then it also might deliver slightly more fuel (although the difference would be very very small).
I'll see if I can find some more info.
Old 02-15-2014, 08:50 AM
Salts's Avatar
Salts
Salts is offline
is this true for the 97's as well? and if I run a standard injector will it hurt the motor at all? or will i need to run the crossover in order to run the standard injector?
Old 02-15-2014, 09:39 AM
clux's Avatar
clux
clux is offline
No the OBS pickups have a different fuel feed system and never had the cackle problem. The LL injectors didn't come about until about 2001.
skywurz
03-03-2015 12:45 PM
QwkTrip
21
04-15-2011 10:11 AM
bralos
12-15-2008 06:05 PM
2danglong
18
04-23-2008 11:05 AM
IceWagon
05-04-2005 11:43 PM
Quick Reply: number 8 injector has different part number
