EcoBoost Ticking at Idle
Hey everyone...here's my first post...just joined the site!
I did a little searching through the forums but was not able to find anything on this issue. Hopefully I am not duplicating a prior post somewhere. Anyhow...I test drove an EcoBoost 150 a couple of weeks ago and noticed that at idle, I can hear a ticking sound from the engine about every second or so. I only hear it when I was outside the cab. It's pretty pronounced but not necessarilly like a "bad" sound. My dealer said it is the high pressure fuel pump. This makes sense in some respects but I wanted to see if this is normal with the new EBoost engine?
Thanks in advance to everyone for your help.
(My new F150 SCrew with EBoost will be in hopefully next week...I can't wait!)
Question for you 2011+ owners:
I've always associated the injector "ticking" as more of a clicking (plastic sound) than a ticking (metallic sound). To me the injectors sound more like a relay click (like the click of a ball point pen) than a metal on metal tick, like say a predetonation "ping".
Are the injectors on the new engines making the same sound as the 04-08s did?
The ticking described sounds like the fuel injectors which on these truck is VERY high pressure similar to that of a diesel. On my 99 PSD I had a programmer which switched up the tune on the fly. You could really hear the difference when switching. Also Fords have a test program with the motor off - you should hear how loud an injector is at 2500psi without the motor running.
The fuel pressure in an Ecoboost engine is over 2000 lbs/square inch compared to maybe 60-80 for a conventional port injected engine. It makes sense that the injectors would have to "clamp" closed very hard because they are right in the combustion chamber and would have to close tightly enough to keep the explosion pressure in the cylinder from kicking back into the injector after they squirt the fuel into the cylinder. Regular port injectors are on the intake side of the intake valve and would have very little pressure to hold back.
Just envisioning the physics here, it seems completely logical that the injectors in a direct injected engine would have to be pretty darn loud to clamp shut during the fuel/air explosions!
And welcome to the site, MKEBoost. Lots of accumulated knowledge here.
George
George
No sir...it was 48 degrees this morning and I let it warm up for about 2 minutes than headed to DD. First red light about a mile down the road, the truck, actually jumped forward with my foot on the brake(as I was stopped at the light). Idle was about 1000 rpm, after a little more warming up, the rpm's hovered from 500 to 700...and no jumping ahead. I didn't have a lot of pressure on the brake, which is probably why it was able to jump forward...but, it was strange to say the least. I definitely will be applying more force in the future.
Been having the same problem as Gixer311 although mine goes a little bit further. I will occasionally have rough idle, somethimes on cold engine sometimes on warm. But have also noticed this roughness at highway speed. I really have to be paying attention to feel it, it is slight, but it is definitely there SOMETIMES!! Also when I am experiencing the rought idle the ticking sound is certainly louder. Have taken the truck to the dealer twice, they could reproduce the issue, they did change the converter but did not correct this issue. Going to leave the truck with the dealer for several days while I am on vacation and told them to let one of their two most experienced techs drive it as a personal vehicle during that time. Hope they can find something. Right now I have 10k on it but its been doing this since around 5k. Considering purchasing extended warranty on this truck just in case. Sure would appreciate any information that anyone may have on this!! Thanks
